08-25-2022, 04:53 PM
Changed rear diff fluid today
Today I hit 29k thousand miles on my 4Runner. I decided to change my rear diff fluid at 29k miles. My 21 Tacoma rear diff went out at 8k so I decided to change my 4Runner as a precaution. My question is should I wait until 50k to change the transfer case and front diff since I hardly put it in 4 wheel drive? I used 75w90 gl5.
08-25-2022, 05:36 PM
I'm doing everything at 50K including the transmission.
08-25-2022, 05:47 PM
I don't have a 4R yet - but owned a 2013 FJ Cruiser from new until 2021. The FJ's owners manual said to run 4WD for a few (10?) miles every month. I did this maybe 8 months of the year. I did not offroad much.
Does the 4R require the same?
08-25-2022, 05:49 PM
Yes I believe all Toyota 4wds recommend this but it's just good practice to exercise your 4wd. Just find a straight road.
08-25-2022, 06:27 PM
My FJ manual stated the same as both of my T4R's............... once a month for 10 miles.
08-26-2022, 03:56 AM
Real Name: Buck
Real Name: Buck
Interesting your rear diff went out at 8k on your taco; I changed my rear diff fluid on my 2019 4R at 3k and it was under filled from factory. Lots of metal shavings and the fluid was shot. I would defiantly change the T-case and front diff.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
08-26-2022, 05:22 AM
I did both diffs and t-case at 25k on a 2019.
Truck saw consistent 4WD usage in that interval.
Rear diff fluid was similar to OP in color, no metal shavings.
Front diff and t-case were honey gold still.
I did not send the rear oil out for analysis but judging by the color alone, it needed to be changed. I would not say my truck sees severe usage but there are months at a time I am in 4WD or on dirt. Another note, I have no breather extension on the rear, had a few deeper crossings but noticed no water contamination when draining.
08-26-2022, 07:27 AM
Yes. I go 50K on both differentials and transfer case using Mobil Delvac Synthetic 75w90. 306K miles on the truck.
08-26-2022, 08:11 AM
Real Name: Ron
Real Name: Ron
This is a good reason for all new owners, whether brand new, or new to you, to check all fluid levels soon after purchase.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
08-26-2022, 09:26 AM
Real Name: Jeremy
Real Name: Jeremy
Good info. Just hit 35K on my 2018 and this is on my to do list. Been getting reminders from the dealership to do all 3 and an injector service for a total of $500..I think I'll be doing it myself..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
08-26-2022, 09:53 AM
on my 17 TRDP, i did both front and rear diffs at 15k miles, now just about at 45k miles and will both diffs, transfer case and trans now.
brake fluid i also do every 2 years regardless of miles
but one other fluid people always for get about is doing the power steering fluid which gets very dirty and is overlooked. Valvoline MAXLIFE atf is a good choice for PS fluid
08-31-2022, 01:44 PM
Nice.
I'm a big fan of changing the diff and trans fluids more often than recommended. I like Amsoil in the diffs, but have used Valvoline in my SxS and it's made that rattling drivetrain nice and quiet.
2022 4Runner TRD Off Road Premium, Front Bilstein 5100’s/Rear Rancho RS9000x, RCI Skid Plate, Goodyear Duratracs.
04-06-2024, 12:46 PM
Yeah my rear diff bolt was loose !
04-06-2024, 06:32 PM
I did my front & rear diffs along with the transfer case last weekend at 50,000km. The transfer case fluid was still golden looking. The front and rear diff looked similar to what is pictured above by Sgb020. I used Redline 75W85 for the diffs and Redline MT-LV for the transfer case.
2021 4Runner ORP - Canada Spec
1989 Land Cruiser BJ74 - Sold
1986 Land Cruiser BJ70 - Rusted Away
