Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
Old 08-11-2020, 07:04 PM #1
Das Capitolin Das Capitolin is offline
Das Capitolin is on a distinguished road
Side mirror swap to add turn signal and puddle lamp
I recently replaced my 2005 4Runner SR5 with a 2019 SR5. While I would have liked a SR5 Premium or TRD Pro, inventory is incredibly scarce during these strange times. At any rate, I got a great deal, but still would have liked side mirror turn indicators and puddle lamps. Unfortunately, these are not available on the SR5 or TRD Off Road.
Visiting eBay, I found these: Fits Toyota 4Runner 14-16 Set of Side Power Mirrors Heated Signal Puddle Lamp | eBay
They claim 2014-2016 fit, but I suspect they also fit 2017-2020. (?)
Aside from reusing my existing painted mirror shells, will these plug into a connection somewhere inside the door? Any experienced advice is appreciated.
Das Capitolin is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 07:11 PM #2
GCT4R's Avatar
GCT4R GCT4R is offline
GCT4R is on a distinguished road
GCT4R's Avatar
Correct me if I'm wrong, premium models are wired for turn signals which the non-premium models are not. So these would not work.
GCT4R is offline   Reply With QuoteReply With Quote
Old 08-12-2020, 06:59 PM #3
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Like gct4r said, your truck may not be wired for the puddles and turn signals.
For the mirror turn signals just wire it from the fender turn signal lights. As for the puddle, wire it from your dome lights.
I’ve read how Tacoma guys are doing the same mod and saw how the did the proper wires in the kick panel. Perhaps 4runner is the same.
I have a limited and my puddle lights turn on when I’m like 3-4 feet away or unlock the doors.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 11-08-2020, 03:07 PM #4
I have successfully upgraded my 2014-2020 Toyota 4Runner SR-5 to use TRD Pro mirrors with turn signals and puddle lamp.
This project would not have been possible without the retrofit wiring harness and detailed instructions provided by Tanner, aka Old Red. With his kit, you can upgrade the standard heated mirrors on a 2014-2020 Toyota 4Runner SR-5 to also include the side mirror turn signal and puddle lamp found TRD Pro mirrors. In upgrading my 2019 SR-5, I used aftermarket TRD Pro mirrors with the aftermarket sequential LED turn signals. I've posted the finished results on YouTube. Total project cost was $270 for all three products.
If you would like more information on the retrofit wiring harness, which was made using OEM Toyota components, visit Old Red's Instagram page.
Old 02-15-2021, 02:54 PM #5
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
Did you use the aftermarket mirrors from your first post? If so, how is the fit and quality of the mirrors? Thanks!
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 02-15-2021, 03:07 PM #6
Yes, I used those aftermarket mirrors purchased off of eBay. They are okay, but fully aftermarket and not an OEM clone. They're still heated, although I have not yet tested that this works, and add signals and puddle lamps. Neither the signals nor the puddle lamps are OEM design, so those components are not interchangeable with OEM. In the end, they work, but they're not quite as durable (wall thickness is about 2mm vs 3-4mm for OEM). The painted shell was interchangeable.
Overall, they are not quite as well made as the OEM component, but you get what you pay for.
Old 02-15-2021, 03:10 PM #7
matoolie's Avatar
matoolie's Avatar
Thanks for the detailed info!
Michael
Old 02-15-2021, 11:59 PM #8
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Lightbulb 2010-13 side mirrors
Shout out to Old Red for all his awesome help ! We discussed getting the 10'-13' yr mirrors as they have better/larger mirror . found some on ebay & same plug & a bigger turn signal light very happy with so far ! Cheaper than buying oem new wow $$$$
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 09:00 PM #9
steraser steraser is offline
steraser will become famous soon enough
I have a '21 TRD Pro which has heated mirrors but no turn signal or puddle lamps. I am assuming that it is not pre-wired but does anyone know for sure?
steraser is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 04:25 PM #10
matoolie's Avatar
matoolie's Avatar
It is not prewired in door harness, so you need aftermarket retrofit door harness from Old Red. Not to mention you need new mirror assemblies with signal and puddle lights.
Michael
Old 04-05-2022, 02:18 AM #11
darrensan's Avatar
darrensan darrensan is offline
darrensan is on a distinguished road
darrensan's Avatar
Hey was planning on doing this mod, but couldn’t find Old Red’s aftermarket retrofit door harness? Or the installation video?
Can anyone help me out? 🤙🏾
2017 4Runner SR5
MAUI, HI
Instagram: @ghostly.t4r
BUILD Page 👇🏼👇🏼👇🏼
https://gearproject.co/gp/ghostly.t4r/662
darrensan is offline   Reply With QuoteReply With Quote
Old 04-05-2022, 10:16 AM #12
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
Interested in this as well
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
TRDHULK is offline   Reply With QuoteReply With Quote
Old 04-05-2022, 12:48 PM #13
JustATallDude JustATallDude is online now
Real Name: Alex
JustATallDude will become famous soon enough
Real Name: Alex
Your best best is to keep on eye on his Instagram, or check the other 4Runner forum. He's apart of that one and I would not expect to see him pop up on this one ever again
2019 TRD Pro Voodoo Blue - aFe Power CAI - Gibson Single Exit Exhaust - Magnuson Supercharger - 2021 Head Unit - Sprint Booster - GTR Ultra2 Highs - Evil Headlights w/ Morimoto LED - Anzo Black Smoked Tail Lights - LED Interior Lights - A-Pillar Phone Mount Mod - CTH Side Mirrors - Eibach TRD Pro-Lift Springs - Falken Wildpeak A/T3s 285/70/17 - FSW F246 17x8.5 with 0 offset - Lasfit LED Turn Signals - DDI Seat Jackers - Apex Overland Front Recovery Points - Old Red's Turn Signal Mod, AMD Mod, and Footwell Light Mod - R4T Blackout Turn Signals - 4Runner Lifestyle Carbon Mirror Caps - BlackVue DR590 Dashcam and more to come...
JustATallDude is online now   Reply With QuoteReply With Quote
Old 04-08-2022, 12:38 PM #14
TRDHULK's Avatar
TRDHULK's Avatar
Mind if I ask why that is?
Old 04-08-2022, 02:59 PM #15
Old Red Old Red is offline
Real Name: I no longer post or contribute to site that doesn't value members or their contributions.
Old Red is just really nice Old Red is just really nice Old Red is just really nice Old Red is just really nice Old Red is just really nice
Simply put, I didn't like watching my time, energy, and effort that I put into my projects get deleted by a mod, to then have my harness designs (IP) ripped off by a certified scam artist that they brought onto this site. I freely gave info and was screwed over for it.
Read about it here:TRD Pro Side Mirror Swap/Upgrade
You might get a good laugh out of it.
Plus, the other site is far better, less adds, better UI. If you have questions, find me over there. Same username.
Old Red is offline   Reply With QuoteReply With Quote
fit , mirror , side , sr5 , trd
Side mirror puddle light upgrade emmantik 5th gen T4Rs 183 01-10-2022 09:30 PM
Quick Q... Is there any 5thGen trim with Side Mirror Turn SIgnal and NO Puddle Lamp? jcage89 5th gen T4Rs 5 01-14-2019 01:34 PM
Problem with mirror turn signal and puddle lights Crseth 5th gen T4Rs 3 01-01-2014 08:34 PM
Led Side Mirror Turn Signal ozrazer Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-19-2006 12:43 PM
