Old 09-01-2020, 01:16 PM #1
umidkusername umidkusername is offline
umidkusername will become famous soon enough
36K miles a year
Any thoughts on the wear and tear of 2020 TRD Pro doing 36k miles a year, 90% highway? I ask because with the upgraded suspension that’s really for off road will this many miles really do a number on the 4runner?
I’m not sure if my vehicle is made for this sort of driving.
Will have regular maintenance, every 5-10k miles. Had oil changed twice so far at around 12k miles.
umidkusername is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 01:17 PM #2
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
should be fine but id expect a shock rebuild (if possible on the stock foxes) after year two prob
tm965 is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 01:21 PM #3
36K miles a year
What should I look for to know it’s time for that?
When I move to where I work I’ll be lucky to get 10k a year unless I do long trips. But if I start doing a lot of off roading the suspension will be used more and I should probably know what to look for.
Old 09-01-2020, 01:23 PM #4
leaks, excessive body roll, bounciness... you'll know
Old 09-01-2020, 01:24 PM #5
CO-Cygnus's Avatar
CO-Cygnus CO-Cygnus is offline
CO-Cygnus will become famous soon enough CO-Cygnus will become famous soon enough
CO-Cygnus's Avatar
Oh my god the gas bills.
CO-Cygnus is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 02:02 PM #6
240 a month. If that breaks the bank probably shouldn’t own a SUV.
Old 09-01-2020, 02:03 PM #7
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
Driving is driving, whether done in 2 years or 20. Keep up with the maintenance schedule and you should be good. One exception from experience:
With that driving style you are an excellent candidate for extended engine oil changes; and our 4 liters are easy on oil. You may want to try an upper tier oil designed for extended life, like Amsoil Signature, Schaeffer 9000, or Mobil1 EP. For the price of a couple of UOAs (used oil analysis) you could likely extend your oil changes out, maybe even yearly depending on results.
I just ran Amsoil 10000 miles for one year of mostly local trips and the report indicated it could have gone a lot further. Using an Amsoil filter which is good for 25000 miles. Doing a second run of Amsoil now and will take it further, probably up to 15,000 miles. I will be running Schaeffer next to compare.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 02:29 PM #8
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
I know it's way different, but I drove my then-brand-new 1988 4Runner the same amount per year. Didn't bother the truck at all. In fact, I started it on average 10-15 times a day, and when I got rid of it at 305k miles, the starter still worked fine. So don't fret too much - these things like to be driven.
thennen is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 02:38 PM #9
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
3000 miles a month is only $240 in gas? Damn I wish mine was that. I’m 15mpg and would be lucky to see 300 miles to a tank. That’s 10 fill ups for me at $50 each so $500 total. New ones must get way better mileage
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 03:09 PM #10
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
That's not true at all.
Putting 36k miles on a car in a year is far better than putting 3k miles on a car for 12 years.
In addition, I'd be very careful using unapproved boutique oils in the car.
36k a year is nothing.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 03:13 PM #11
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
203,000 in 8 years mixed driving with some mild off roading for fishing. Probably 10-15k of that was vacation road trips. 19mpg consistent.
3rd set of tires on it now, getting 60-70k per set
3rd set of brake pads on it, all had meat left when changed every time
put new shocks on at 140k, one was leaking, went with OEM Tokico's
front wheel bearings once, I drive through a good bit of water
Did rotors at first brake pad change at 100k for the hell of it since pads were so old. Probably didn't need, but safety.
Replaced sway bar bushings around 150k for a clunk noise
Oh, and I do 5kOCI's with Toyota oil, but have used mobil one for a little while, tried several others, like Toyota best.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 06:40 PM #12
peekaboo peekaboo is offline
peekaboo is on a distinguished road
I do not believe these Fox shocks are designed to be rebuilt.
OP, I'd almost buy a set of shocks for your current driving habits and put the Fox ones back on when it changes.
peekaboo is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 07:31 PM #13
thennen's Avatar
thennen's Avatar
It’s not so much new vs older, but stock vs modded. Yours is lifted with bigger tires, right? That does a number on the MPGs. Mine is stock and I routinely am around 22mpg, and 400+ miles per tank.
Old 09-01-2020, 08:38 PM #14
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
This isn’t an mpg thread, but my Pro is 16.4 over 10k miles, hand calculated. Only mods are TRD CAI and exhaust, and aluminum sliders, with conservative driving.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 08:39 PM #15
I agree with you that highway miles are the easiest on a vehicle and 36k/1 year is easier than 3k for each of 12 years.
But I am wondering what your foundation is for being "very careful using unapproved boutique oils". Are you saying that an oil from a company other than some large company with a huge advertising budget isn't good enough? If not, what exactly are you saying?
I mean, Toyota's owners manual for the 2020 4Runner says:
Originally Posted by Toyota
■ Engine oil selection
“Toyota Genuine Motor Oil” is used in your Toyota vehicle. Use
Toyota approved “Toyota Genuine Motor Oil” or equivalent to satisfy the following grade and viscosity.
Oil grade: ILSAC GF-5 multigrade engine oil
Recommended viscosity: SAE 0W-20
It doesn't say anything about "approved oils", other than that it should satisfy the ILSAC GF-5 multigrade requirements. Also note that 0w-20 is recommended rather than required. In other parts of the world, our 4.0 V6 engines are specified to use viscosities up to 20w50.
Between outfits.
12k , 36k , miles , vehicle , year
WTB: 05-10 year 4runner, less than 90k miles Iopmorgan Want to Buy/Trade 0 09-20-2014 06:27 PM
1 year old today & 54K miles WV runner 5th gen T4Rs 20 12-30-2013 09:01 PM
what year and how many miles Big Norm Classic T4Rs 49 02-12-2009 05:01 PM
What year and how many miles so far..... Falls 4th Gen T4Rs 64 04-16-2008 09:35 AM
How many miles a year do you drive? 4RunnerWV 4th Gen T4Rs 41 03-24-2005 08:01 PM
