Old 10-16-2020, 05:11 PM #1
JRod0981 JRod0981 is offline
JRod0981 is on a distinguished road
ARB Compressor and Auxiliary Fuse Box
Anyone run an ARB compressor through an auxiliary fuse box? If so, what fuse box did you use? The Blue Sea ones that everyone in the world seems to like has a 30 AMP limit for each circuit. The compressor needs a 40 AMP fuse and uses 2 40 AMP fuses if you get the twin.
My hope was to run all my accessories (light bar, rock lights and compressor) through the fuse box as I hate having in line fuses off the battery.
JRod0981 is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 01:47 AM #2
JD-241 JD-241 is offline
JD-241 is on a distinguished road
I had the same idea and never found a solution. What I concluded was that I'd run the air compressor straight to the terminals and everything else off a fuse block when I get around to buying. It is possible other fuse blocks with higher ratings exist, but I also consider electricity to be a form of magic so I tend to go for pre-built kits (which do exist for the 4Runner with Bluesea equipment).
JD-241 is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 02:12 AM #3
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
You have two options here:
1- run it with a blue sea fuse box and 30A fuse. If it keeps burning fuses then:
2- run its own wiring with an in-line fuse just like the portable version they sell
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 10-17-2020, 02:14 AM #4
borfoo3's Avatar
borfoo3's Avatar
Risky stuff here.. the fuse is your safety kill switch if something goes wrong with the circuit..
Old 10-18-2020, 11:43 AM #5
Completely agree here. I wouldn't run this thing without a fuse. Especially since the compressor can have a variable load. Just haven't been able to find a fuse block that supports a 40 AMP circuit and didn't know if anyone else did this. I would imagine these have to exist and that it would be ok to do since you have fused the circuit for the compressor.
Old 10-18-2020, 01:20 PM #6
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
If you want to control the compressor using the fuse block, I'd run a relay capable of handling the current load from the batery and then run the switching circuit off the fuse block.
High draw accessories such as compressors, winches etc. are commonly wired straight to the battery (with appropriate inline fuses of course) for the power leads. The switching is done off a separate low current circuit which can easily be fed from an auxiliary fuse block.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 10-18-2020, 01:48 PM #7
bring_it_on's Avatar
bring_it_on bring_it_on is offline
bring_it_on will become famous soon enough bring_it_on will become famous soon enough
For higher current applications, Blue Sea makes the SafetyHub (100 & 150) line of fuse blocks that allow a limited number of high current (up to 200 A) connections in addition to the 30A or below devices. A bit pricey but they will last quite a while and allow you to mount all your high current devices (compressors, DC-DC chargers etc) through them instead of running individual in line fuses etc.
SafetyHub 100 Fuse Block - Blue Sea Systems
2019 TRD Off Road| 285x70xR17 Falken WP AT3W| Dobinson C59-314/GS59-700 & C59-505/GS59-701| Total Chaos UCA| RCI front skid plate (steel)| C4 Fab. Low Pro. Bumper| Extreme LED Light Bar (bumper)| Baja Designs Squadron Sport Fog Lights (Amber)| Bud Built Ultimate Rock Sliders| Front Runner slimline II full-size Roof Rack with Wind Fairing| C4 Fab Summit Hatch Ladder| ARB CKMA12 Air Compressor| Xenon Depot HID Low Beam Head Lights|Renogy-20 Amp DC-DC Charger|Battle Born LiFePO4 Auxiliary Battery| Goose Gear rear drawer system (8")|National Luna 52L Legacy Fridge/Freezer| Alu-Cab tilting fridge slide (Small/Medium)| ROAM Adventure 8' Awning
bring_it_on is offline   Reply With QuoteReply With Quote
Old 10-18-2020, 03:50 PM #8
Or that Nice find.
Gone
Old 10-20-2020, 01:22 AM #9
The ARB compressor comes with inline fuses.
Last edited by JD-241; 10-20-2020 at 01:27 AM. Reason: still learning how to use forums
Old 10-20-2020, 11:08 AM #10
I know. I'm waiting to incorporate that 40 AMP fuse(s) it comes with into a fuse box and not use inline fuses to lessen the number of inline fuses and wires coming off the battery. Makes the engine bay look cleaner. Anyone done this with the compressor?
Old 10-20-2020, 11:11 AM #11
This is great. Thank you. I might have to try this.
amp , arb , box , compressor , fuse
Auxiliary fuse block bracket November Sun 4th Gen T4Rs 7 03-29-2023 12:58 AM
Electrical Help on Auxiliary Fuse Box Longhorn425 5th gen T4Rs 2 09-14-2020 03:11 PM
Auxiliary fuse box in back kolelt 3rd gen T4Rs 20 06-29-2016 12:45 AM
auxiliary fuse block 7echo 3rd gen T4Rs 25 12-17-2015 07:55 AM
Auxiliary Fuse Box Question JSparky General Discussions 3 06-27-2015 02:58 PM
