Old 01-31-2023, 03:52 PM #1
CSM4runner's Avatar
CSM4runner CSM4runner is offline
CSM4runner is on a distinguished road
CSM4runner's Avatar
base trail model rearview mirror
I bought my 4runner base trail edition in 2016 with 4k miles on it. The previous owner installed a remote starter (module shown in pics). Fast forward to today and I'm trying to install a dash cam by using power from my rearview mirror. The problem is there are no wires/power to my mirror. Did the 2016 base trail rearview mirror not have power?
edit- the pics didnt load. I'm Curious if the power for the mirror wasn't used for the remote starter.
https://ibb.co/k2LZFJk
https://ibb.co/6R7ZwBr
https://ibb.co/y4CwsZN
2016 4Runner Trail w/KDSS / Dobinsons 3/2" / Camburg UCAs/ KO2 275/7017 / Light Bar / Raptor Lights / Rockford Fosgate amp/ Rockford Fosgate P3 subwoofer / Thule 60" Aerobars
CSM4runner is offline   Reply With QuoteReply With Quote
Old 02-01-2023, 04:55 PM #2
CSM4runner's Avatar
CSM4runner's Avatar
Ok, today i took the over head console down and there isn't power running to the mirror or remote starter. remote starter runs along the top of the headliner and down A-Pillar. Now i need to figure out if I can just use that to power dash cam.
Can i tap into this for power?
Just a moment...
Old 02-02-2023, 01:29 AM #3
ED_96Ltd's Avatar
ED_96Ltd ED_96Ltd is offline
ED_96Ltd is on a distinguished road
ED_96Ltd's Avatar
Definitely recommend using a fuse-tap and running it down to the fuse box by the pedals. Then just pick your fuses to tap based on if you need constant power or only accessory.
Side note though: I'd stay away from tapping into anything critical to the car's operation. As in, it's better that your radio or wipers don't work rather than your fuel pump relay in the event that the fuse-tap malfunctions somehow. IIRC from installing my dash cam, I believe there are actually a few powered open slots that I would check first before tapping into a preoccupied slot.
'96 4Runner Limited - 327k miles
- OME 881/890, Bilstein 5100's, BFG KO2's (265/75/16)
'14 4Runner Trail Edition - 162k miles
- Diode Dynamics SS3 Fogs, XenonDepot DRL/High Beams, Cooper Discoverer A/T's
ED_96Ltd is offline   Reply With QuoteReply With Quote
Old 02-02-2023, 11:18 AM #4
CSM4runner's Avatar
CSM4runner's Avatar
Ed, thanks for the reply and recommendation. I think I'm going to use this;
Toyota 12v Fuse Kit W/5Amp Mini Blade Fuse | Cali Raised LED
Old 02-03-2023, 02:19 PM #5
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
There are some other considerations here. Before any power source is tapped into, it's a good idea to check what current rating that source is and if it can handle the extra load of the accessory you want to add.
base , mirror , power , rearview , trail
Need Help. 5th Gen Rearview mirror MasterBlaster 5th gen T4Rs 5 04-18-2018 11:06 AM
Rearview mirror yeauxkna_at 4th Gen T4Rs 6 06-05-2013 02:24 PM
How do you remove rearview mirror base utvolyaker 3rd gen T4Rs 2 07-05-2012 03:45 PM
Rearview mirror ?? Net4n6 General Discussions 0 09-19-2009 02:09 PM
I'm new and need a little help with a rearview mirror srewen Classic T4Rs 0 11-26-2008 02:43 AM
