01-03-2021, 10:04 AM
What battery you using?
My battery decided that 2020 was too much and didn’t make it to 2021. What deep cycle is everyone running? I have fogs, light bar, and ditch lights wired directly to the battery.
'17 White Off Road Premium - XD Xtreme HID - LED Fogs - Turn as tail - Interior LED - Blacked Out TRD Emblems - Endless list of mods - Sexy blonde riding shotgun
01-03-2021, 12:04 PM
I am using X2Power Premium AGM Battery. Its made by northstar. Its little expensive, but its worth the price. No modification needed. its a beast!
01-03-2021, 12:20 PM
If you keep the engine running, the alternator is more than enough to power every thing you have, thus a deep cycle battery is not needed.
However, if you are not running the engine, and you have loads like a refrigerator you need running all the time, then a deep cycle would be needed, but usually as a secondary battery.
When I look for a new battery, I always look for capacity (amp hours), cold cranking amps and warranty. The battery omr gh recommended would be great in that regard.
Many people have gotten batteries from Costco (Interstate batteries) that are good, and I have gotten batteries from lowly Walmart because they had ones that met my criteria (capacity, CCA, warranty).
I've learned to avoid Bosch batteries (Pep Boys) because I have had really bad experiences with them failing even during warranty.
01-03-2021, 12:53 PM
01-03-2021, 01:17 PM
Following. In need of a new battery for my 2016.
2016 Trail MGM - BFG KO2 275's - 5100's set at 2.5" - Rear Daystar 1.5" - Hefty Fabworks frame sliders
2010 SR5 MGM - sold
01-03-2021, 02:51 PM
I use a Northstar NSB-AGM27F. It's a bit larger than the stock battery but fits without issue in the stock location. You do need to either charge it regularly or use one of the voltage boosters to keep it healthy and prolong it's life.
NSB-AGM27F
01-03-2021, 05:24 PM
Real Name: Chris
Real Name: Chris
I love my Odyssey battery, after several bad Optimas in a row, I made the switch to Odyssey and run them in both my cars now
01-03-2021, 05:39 PM
Same here, and my battery issues are gone now that I do not drive daily. Batteries Plus had it on sale plus an additional 10% off plus %30 rebate.
Search Results for SLI24FAGMDP at Batteries Plus Bulbs
2016 4Runner Limited
01-03-2021, 06:36 PM
Real Name: Justin
Real Name: Justin
NorthStar 24F AGM battery w/ GM diode mod
I have no plans on going duals
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
01-03-2021, 08:08 PM
Otima & Odyssey One of each
The Otima fits the shrockworks tray
The Odyssey fits the OEM Tray with the bottom adapter ( order the adapter with the Battery its like 5 bucks). Takes 5 mins. to install.
One and Done.
signature not available
01-04-2021, 10:23 AM
unless you are using your lights for prolonged periods with your engine off, these shouldn't require the use of an AGM battery
01-04-2021, 10:31 AM
Real Name: Special Ed
After 11 years, my Deka/East Penn made Advance Auto Parts battery finally is dead.
Bad cell.
(I do maintain my batteries, and it is wet because I had cleaned it prior to placing on a charger which states dead cell)
I have a Deka Ultimate in everything else.
I think their TOTL line name changed though.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
01-04-2021, 10:56 AM
2021 JGC Trailhawk (waiting for the 6th Gen 4R
2015 Silver TE: (SOLD) KDSS, ICON stg 2, Magnuson, Victory Blitz sliders, Fuel Blitz DDT 18x9 w/ -12o/s, 275/65/18 Nitto TGG2, ARB skids, Spidertrax spacers, Alpharex Luxx, Rigid 40” Stealth LED bar & 360 fogs, Switch Pro 9100 w/ Mount Tray, KC Flex Dual Ditch Lights, KC Cyclone Rock Lights, LED interior, SSS hybrid winch bumper, 30" Rough Country single row LED, Alpine ILX-F308/R line speakers, 8" Alpine Powered Sub. Prinsu Full no-drill roof rack.
01-04-2021, 11:10 AM
Still OEM at the moment, but in the cold, starts are not turning over as quickly as last year.
I have usually gone with Interstate in the past.
Between outfits.
01-04-2021, 11:44 AM
Originally Posted by Paragon1
$800+?
WOW!
I like quality stuff, but there is no way I can justify that even with a hefty sum of audio equipment.
