Old 02-20-2021, 05:58 PM #46
Carova Colton Carova Colton is offline
Carova Colton is on a distinguished road
Also of note, I tried to do the ECU reset with the 4 and 13 pin jump and now the starter doesn’t even give me a click and the electronics restart when I hit the push start. Uuugggh
Carova Colton is offline   Reply With QuoteReply With Quote
Old 02-20-2021, 06:24 PM #47
Sonoran_Desert Sonoran_Desert is offline
Real Name: Jo
Sonoran_Desert will become famous soon enough
Real Name: Jo
Sorry to hear. I guess two options are take to independent toyo mechanic or call insurance company.
These trucks go through water all the time. I suppose there is a fine line between OK and not OK water levels. Possibly somebody can explain at what point it is too much water.
Sonoran_Desert is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 09:47 AM #48
I also tore the wires out of the sensor that is on the valve cover just below the #4 cylinder. The wires to the coil pack and the sensor were taped together and of course I didn’t cut them apart. When I pulled the plug out of the coil pack I jerked the plug back and ripped those small wires clean out of the sensor. I don’t even know what the sensor is. Any help would be appreciated. I will have to buy a new wire harness for it I guess.
Old 02-21-2021, 12:32 PM #49
Woke up this morning and got a small hose to blow out the cylinders then went to rotate the pistons with the crankshaft pulley and it will now only turn a 1/4 turn in each direction until it stops and won’t move. Is this a broken ring maybe?
I can’t take it to insurance because it was a salvage title vehicle that I got and repaired. Insurance would give me nothing for it. Is there any way to check and repair without pulling the engine?
Old 02-21-2021, 01:39 PM #50
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
If the engine was running when it took water into the cylinders, it's done. One or more connecting rods bent, valvestem(s) bent is the usual outcome. I've seen a GM engine deform a connecting rod during cranking after a fuel injector stuck open while shut down, filling the cylinder with raw gasoline which, like water, is also not compressible.
If the engine wasn't running, you likely formed a rust ridge on the cylinder wall(s) while the engine sat. The rings hit this while you're turning the crank, and stop. A soaking with Marvel Mystery Oil in all cylinders might help loosen it up.
waypoint is offline   Reply With QuoteReply With Quote
Old 02-21-2021, 03:53 PM #51
Ok, miscue there. I removed the serpentine belt and I can rotate 360 degrees and seems fine. Used a compressor to blow out the muck and water and yes there was some in 3 cylinders. Now going to do a compression check on each cylinder and wait for the new ECU to arrive.
Old 02-21-2021, 06:59 PM #52
Here is a pic of the sensor I destroyed.
Flooded my 4runner passenger side!-ad85d9b4-9b16-4595-b9e8-90906c2d00e7-jpg
Old 02-21-2021, 07:00 PM #53
Can’t really do a compression check without the engine turning over so will have to wait.
Old 02-21-2021, 09:19 PM #54
waypoint's Avatar
waypoint's Avatar
Get oil into the cylinders to prevent rust ASAP. A can of storage fogging oil from the parts store is the ticket, just stick the straw into each spark plug hole and give a good ~2 second shot. Then rotate the crank at least one full revolution and do it again.
Old 02-21-2021, 10:06 PM #55
Thanks brother! Will do. I shot WD40 in each cylinder but fogging oil would be better. Thanks
Old 02-21-2021, 10:07 PM #56
Any idea what that sensor is that I torn the wires out of? I circled it in the pic.
Old 02-21-2021, 11:11 PM #57
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Camshaft position sensor.
02SE is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 01:04 AM #58
Thank you, looks like I can buy a new plug and splice the wires. Cheers
Old 02-22-2021, 09:21 AM #59
PhillySilver PhillySilver is offline
PhillySilver is on a distinguished road
Man, super sorry to hear about this. I read this whole thread yesterday and it is a total bummer. As was posted earlier, getting some oil into the cylinders right away to keep the rust down is important. Also getting those electrical connections blown out and dry before they start to corrode.
While not to this extent, I had some water damage to a an old Pathfinder I had and I think you really need to get any interior parts with foam out right away and either write them off as gone or get them drying. Mine happened in the summer so I ripped out the carpet and dried them in the sun for a few days. Seats, try and get them into an environment with a good strong dehumidifier to try and get that water out. The mold starts to set in very quickly.
Even with all this, there was a slight mold smell in it all the time and on really humid or rainy days it proper stuck in there. I always found that the windows fogged up at the slightest bit of humidity which makes me think I never got it dry to begin with.
As others have mentioned, might want to at least check with the insurance company. Another option if you can't get insurance involved is to maybe declare it a loss and part it out to recoup some of your costs. That's the "nuclear option" though and I hate even suggesting it.
Whatever you end up doing, hope it works out.
PhillySilver is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 09:22 AM #60
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Use this link below to a service manual which may help you as you trace things out. Good luck!
Toyota 4Runner Service Manual
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
carpet , disco , dry , engine , seats
WTB 2nd gen 4Runner passenger side headlight Mkrespke Want to Buy/Trade 0 03-15-2017 11:26 PM
My town is flooded, might have flooded my engine. What can I do to fix it? DeadbeatYota 4th Gen T4Rs 36 01-09-2016 09:09 PM
WTB 2013 4runner passenger side rocker panel side skirt vinodmp Want to Buy/Trade 0 10-27-2014 10:52 AM
06 4Runner passenger side mirror hgill For Sale: T4R Items 2 07-08-2014 01:08 AM
