Old 02-24-2021, 09:29 PM #46
StuB StuB is offline
StuB is on a distinguished road
E-load range in stock size is part of the problem. But a bigger part is that the steering rack design on the 4th & 5th gen T4Rs is super sensitive to balance issues no matter the tire brand. And I'll toss out that every time I've strayed from BFG All Terrains, I've been unhappy and have gone back - Goodyear, Yokohama and Cooper...
StuB is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 09:39 PM #47
SidKo's Avatar
SidKo SidKo is offline
SidKo is on a distinguished road
SidKo's Avatar
Glad to see this posting. I am approaching that same scenario - Coming up to 4 years and 45K on these sets of KO2.
They have been great except for wet environments. I find it lacking when stopping in wet pavement.
As for my use, I have the snow in the Catskills of NY and the beaches of Long Island. This year was pretty intense with the snow, especially in the country side. When I drive on the beaches, I air down to about 18 psi. I have yet to find myself in a stuck situation.
As others have mentioned, the Toyo Open Country AT3's has caught my attention.
SidKo is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 04:50 PM #48
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
BFG KO2 (C)
Im running the E right now and they were a little fussy; had to balance 1 time after install and they said to keep them at 35-40 PSI and that Helped Big Time.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 05:32 PM #49
702_SR5 702_SR5 is offline
702_SR5 is on a distinguished road
Originally Posted by StuB View Post
...The steering rack design on the 4th & 5th gen T4Rs is super sensitive to balance issues no matter the tire brand. ...
Is there a fix for that?!
702_SR5 is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 05:34 PM #50
Originally Posted by Hammer0313 View Post
BFG KO2 (C)
I normally run 37-40 on the pavement. 37 is of course the OEM spec for the stock tires. I don't recall getting a special pressure recommendation any of the shops I've been to during my ordeal.
Old 02-25-2021, 05:35 PM #51
DEUS-MACH1NA DEUS-MACH1NA is offline
DEUS-MACH1NA will become famous soon enough DEUS-MACH1NA will become famous soon enough
I ran KO2's on another 4R and could not get them to hook in the rain and occasional snow here in the PNW; fun breaking the rear loose with ease, but got too squirrelly and unpredictable.
Running Wildpeaks on my 5th gen and they grip and stop well in the rain, snow, forest roads and sand dunes.
DEUS-MACH1NA is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 05:48 PM #52
SilverTEP's Avatar
SilverTEP SilverTEP is offline
Real Name: Luke
SilverTEP will become famous soon enough SilverTEP will become famous soon enough
SilverTEP's Avatar
Real Name: Luke
Coming from KO2s 275 / Es, I'm extremely happy with Toyo AT3 285 / C. They give you a lot of confidence in the rain as oppose to KO2s. KO2s are solid in everything else, AT3s keep up, tiny bit worse in snow if not aired down.
AT3s are also made in SL load
2018 TRD ORP w/ KDSS, Hefty Front Bumper, Ironman4x4 Pro Foam Cell, RSG Sliders, Nitto RGs 285/75/17 E, Victory 4x4 full steel armor, Diode Dynamics Fogs
SilverTEP is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 05:49 PM #53
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
32 psi front and rear is what should be on the sticker in your driver side door. LT tires get +10 psi compared to the oem P-metric tires, according to this: Tire Pressure Calculator
I did a chalk test on my E loads at 42, and this estimate was pretty accurate.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 05:55 PM #54
Originally Posted by Gstick View Post
... Are you sure that the shop that is using the Road Force Balancer knows How to use it properly ? I'm not trying to be a smart ass with this question, but Toyota Wheels are the hardest to balance because of the large center hub diameter, & there are special inserts for RF balancing machines to fit the Toyota wheels perfectly.
At one point, I took the vehicle to my local dealer, explained what was going on, and asked them to fix it. What they did was rebalance and road force the wheels. Then (without telling me), moved them to the positions on the vehicle where the problems would be least noticeable. I realized this because I had numbered the rims and I saw they had been shifted around.
When the wheels were moved back to the spots they were in, there was practically no improvement in the ride quality.
I've stood next to the technician in different Discount Tire shops and watched them do the road forcing and force matching when needed. To me, the wheel appeared to be on the machine solidly. I'm not sure exactly what this adapter is that I've heard about, but I would expect them to have whatever was needed.
Old 02-25-2021, 06:14 PM #55
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
@Tuco S. is correct. 32 psi is the recommended pressure for stock tires on the 5th gen 4runner. The recommended pressure for every vehicle is listed on the sticker on the B pillar inside the driver door. I am currently running my BFG KO2s in load range C at 37-38 psi on the street.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 06:19 PM #56
OK, my mistake, I should have walked out to the garage and double-checked before posting.
Still, as stated, I am running the KO2 E's at 37-40 psi. Are you suggesting I run them higher or lower than that?
Old 02-25-2021, 06:31 PM #57
Locust Locust is offline
Locust is on a distinguished road
I am primarily in the Reno and Winnemucca area in Nevada and have the stock Nitto Terra Grapplers that came on my TRD Pro. I have about 27k miles and they have lost significant capability in the sand/rock. I've driven in some "interesting" snow and ice situations around the Sierra Nevada range and I've never been stuck, but I am looking to switch to K02's just from a durability standpoint.
2019 VooDoo Blue 4Runner TRD Pro
- Agency Power CAI, URD Y-Pipe, Rago Fabrication low profile ditch light brackets with Baja Designs Squadron Sport ditch lights, Rago Fabrication modular storage panels and shelf, Westcott Designs lift, custom made sleeping platform in trunk space.
Locust is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 07:54 PM #58
Titan_Bow Titan_Bow is offline
Titan_Bow is on a distinguished road
I've literally put hundreds of thousands of miles on BFG AT's, with many of those miles on forest service roads and non-pavement out here in Colorado, Wyoming, Nebraska, Montana, both E and C rated tires, and knock on wood, I've never had a flat. I took my wife's Subaru on a hunting trip this year and on the second day of driving county dirt roads in eastern Colorado, I had a flat tire, with Falken Wildpeaks... I know, I know, its not an apples to apples, but my point is, BFGs have never let me down. I've never experienced poor traction with them in snow or rain either. I hear that a lot, and maybe its just that where I live, we just dont get that much rain, and when it does rain, its usually short events that are over quick. But I drive a lot in the snow, and BFGs have always felt solid and had confident grip.
Titan_Bow is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 09:42 PM #59
wcslv wcslv is offline
wcslv is on a distinguished road
When the time comes, I’ll be going to Mickey Thompson ATZ P3. I had them on my Duramax and they were unstoppable. Goodyear tires I always had problems balancing them. So I quit using them. Mickey Thompson and BFG no problem.
2019 T4R TRD PRO
wcslv is offline   Reply With QuoteReply With Quote
Old 02-26-2021, 12:08 AM #60
Hey man no worries. It really depends on your weight. The chalk test is best to determine what psi is best for your setup. I had load range E Falkens for a long time on an F150 and ran them at 40 psi all the time and they wore completely evenly and lasted forever. I actually had the rears a little less about 38 psi since I didn't have weight in the bed constantly. But if I put a heavy load back there I'd air them up a couple psi just to handle the weight a bit better.
With the 4runner being an SUV, and I have a decent amount of constant weight (sliders, skids, roof rack, roadshower, sleeping platform), I run all my load range C tires pretty evenly all around at 37-38 psi. That's where I found the tire wear to be the most even and get the best contact patch with the ground. Below that, the outside tread was wearing quicker than the inside. My tire wear is a bit uneven at the moment but it's getting better now that I've done the chalk test and adjusted the pressure.
Normally you run a load range E tire at a bit higher pressure than a C...normally because if you have a load range E tire you're generally trying to have it bear more weight. BUT everything depends on your weight. A same size load range C tire and load range E tire at the same pressure will be rated to bear the same weight. E tires can only bear more weight because they're rated for a higher maximum pressure. You might already know this.
flat , ko2s , problems , set , tires
What is this, and can I move it? BusinessHippieRH 4th Gen T4Rs 8 03-24-2017 08:39 AM
I Want to Move 4Running Daily 3rd gen T4Rs 23 04-10-2012 01:20 AM
Possible move from 3rd gen to 4th gen OHP 4th Gen T4Rs 15 02-07-2012 11:28 AM
Im ready Im ready Im ready. Pics of the tires and cb Opi 3rd gen T4Rs 12 03-17-2011 05:21 AM
'03 V8 won't move Bacon 4th Gen T4Rs 7 02-24-2009 01:16 PM
