Originally Posted by m85476585
You don't need it. The transmission/computer is smart enough to know when there is more load, and it holds lower gears longer. It's most noticeable driving up hills with or without a trailer. It will also downshift for you on downhills if you lightly hold the brake for a few seconds. You can shift it to 4 if you want to keep it out of overdrive, and it will still shift between 1-4 as needed.
That's not really true.
The 4Runner is really just not big/strong enough to be used as a tower/hauler so it doesn't have any of the features you'd normally see in a tow rig like a big radiator, transmission cooler, or a tow/haul transmission setting.
The best thing to do is to set it to S mode and either "4" on flat surfaces or "3" in the mountains.
If you want to tow regularly, you have the wrong vehicle.
