Thread Tools Rating: Thread Rating: 8 votes, 3.63 average. Display Modes
Old 09-11-2011, 11:13 PM #1
rc_80 rc_80 is offline
rc_80 is on a distinguished road
Pulled out 3rd Row Seats on Limited - Flooring Ideas Anyone?
Hi All, new to the forum!
I purchased my 2011 limited about 2 weeks ago (traded in my 08 Prius). I basically need to haul a bunch of film equipment and a 5' Magliner cart and wanted to get a flat cargo surface but the dealer only had the limited with the 3rd row option. The sliding cargo tray option looked impressive but they did not have it in the model i wanted. Another issue I have is that the back seats don't fold down flush like the models without the 3rd row.
So today, I decided to remove the 3rd row seats. Removing them took about an hour. I worked my way from the back to the front - removed the covers and unbolted the seats. They came off pretty easily. The two 3rd row seats are pretty heavy. I am glad to not be hauling that much excess weight around anymore. I think I also gained about 7" of vertical cargo space in the back.
I was wondering if anyone had some ideas on how they might approach the flooring for the cargo area. Would you simply have it carpeted, place a stiffer surface and then carpet it, or build a lower cargo shelf and then build a stiffer surface on top of that for the heavier and larger items. The last option seems more practical to me as I can roll my cart all the way in and have the cargo area somewhat level to the back seats when they are folded down.
I have attached some images from the 4runner. Lastly, anyone interested in some 3rd row seats?
The Prius was wonderful but I really love the power and the feel of the the 4runner. I always felt like I was overloading my prius with gear. The next few projects I have in mind are: 17" TRD wheels, removing chrome, and a new roof rack. Looking forward to hearing from you.
Thanks,
RC
Pulled out 3rd Row Seats on Limited - Flooring Ideas Anyone?-img_2923a-jpg  Pulled out 3rd Row Seats on Limited - Flooring Ideas Anyone?-img_2929a-jpg  Pulled out 3rd Row Seats on Limited - Flooring Ideas Anyone?-img_2930a-jpg
rc_80 is offline   Reply With QuoteReply With Quote
Old 09-12-2011, 04:31 PM #2
wvanstone wvanstone is offline
wvanstone is on a distinguished road
Is it possible just to take one seat out and still leave the covering material in place for that one seat? I would like to remove one sear and replace it with a security box or shelf.
wvanstone is offline   Reply With QuoteReply With Quote
Old 09-12-2011, 04:55 PM #3
gwcpa gwcpa is offline
gwcpa is on a distinguished road
That's interesting how much higher the second row seating is than the rear floor. How does the floor go flat on the non-3rd row models? I guess the backrests fold at a high fulcrum point, and they don't recline?
Can you just use a non-3rd row cargo liner and some black carpet to cover the other exposed metal?
2013 Limited 4x4 Classic Silver Metallic
2011 SR5 4x4 BP...Sold
gwcpa is offline   Reply With QuoteReply With Quote
Old 09-12-2011, 05:11 PM #4
The covers run all the way across the back of 4runner and it is the same height as the 3rd row seat. I suppose, if you built a box to accommodate the cover, you could make it work.
I don't think you can cut it easily - there is the carpet/board material on the top and then underneath that there is a metal sheet that bolts onto the seat frame and the vehicle. There is also that big plastic piece that runs along the back too.
Old 09-12-2011, 05:13 PM #5
andy24 andy24 is offline
andy24 is on a distinguished road
I am interested in the seats. How much?
andy24 is offline   Reply With QuoteReply With Quote
Old 09-12-2011, 05:26 PM #6
terra4r's Avatar
terra4r terra4r is offline
terra4r is on a distinguished road
terra4r's Avatar
I would build up the floor to the level of the rear lift gate, and carpet it. Under floor storage would be nice (hinged floor section), at least a place to throw some items you always have in the car.
-Jim
'11 Mag Grey SR5 4WD Premium Pkg.
OEM door handle LED's, Mud and hood protectors, Infinity 32.9cf's
terra4r is offline   Reply With QuoteReply With Quote
Old 09-12-2011, 05:26 PM #7
Jtraskell Jtraskell is offline
Jtraskell is on a distinguished road
This is an interesting photo. (The one above with the 3rd seats removed). I have an SR5 with no 3rd row seats but I do have the sliding tray. I was amazed at the above photo of how much room is now exposed without the trim in the cargo area floor. The SR5 Floor, with sliding tray, is even with the backs of the second row seats when folded down. The reason I think is our floor is raised pretty high off the steel as compared to what I am seeing in the above photo. Do you see those two cubby holes on either side above the wheel wells in the photo above. (The one on the right has something white in it). My SR5 does NOT have those storage holes. However, do you see the ridge about 12 inches or so below the holes? I also have that ridge. (Well, at least I think it is the same ridge). The top of the none moving floor of the cargo area is at the same height of that ridge. Then, the top of the sliding tray is another 3 or 4 inches above that. When the rear seats fold flat, the top of the sliding tray is even with the now folded seats. So it looks like I have another 3 or 4 inches of empty space from the top of my carpeted cargo floor (not counting the sliding tray) to the actual steel of the cargo deck. And yes, my rear seats recline. To fold, the rear seat bottom's fold forward fist, resting against the rear of the front seats, then the back's fold down flat.
2010 Salsa Red SR5, Black Power Leather Seats, Sliding Rear Cargo Deck, Luggage Rack Cross Bars, Black Pin Stripes, Black Body Side Moldings, Front and Rear 120v outlets, Husky Floor and Cargo Mats, Wade Window Vents, Autovent Shade Bug deflector II, Modified Trailer Electrical Connection, Rear View Camera, Michelin LTX M/S2 285/70/17, Load Range D, OEM Hood Insulator. Blacked out front emblem, front, rear and side chrome strips, Blacked out and modified rear emblem, luggage rack and black OEM door handles.
Jtraskell is offline   Reply With QuoteReply With Quote
Old 09-12-2011, 05:35 PM #8
Ahh, ok, now I see. The 2nd row just has the back fold, and not the bottom forward first. That's where the additional height comes from to make the 2nd/3rd even.
I don't have the 3rd row or tray, and my cargo carpet/mat is right on the steel floor.
Old 09-12-2011, 05:43 PM #9
You got it. And you are right. That ridge I talked about above, is much different then on mine I guess. I remember Harper7 took out both the tray and floor in his cargo area just to see what's there, I found those photos here:
Removed the Rear Sliding Tray-5TH Gen Limited
As you can see, only an extra inch or so from the top of that ridge to the top of the steel floor. So, we have what we have! Be safe.
Old 09-12-2011, 05:51 PM #10
Renegad44's Avatar
Renegad44 Renegad44 is offline
Location: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Renegad44 is on a distinguished road
Renegad44's Avatar
I had the dealer remove one of the 3rd row seats, than told him that's ok, find me a slide out cargo tray.
Renegad44 is offline   Reply With QuoteReply With Quote
Old 06-12-2012, 08:45 PM #11
CraigRoberts's Avatar
CraigRoberts CraigRoberts is offline
CraigRoberts is on a distinguished road
The dealer only had a used 5th gen LE with 3rd row when I bought as well...
I'd like to pull out these and make some extra room for cargo. Did you ever figure out what to cover the space with?
2010 Toyota 4Runner Limited (Mag Gray)
CraigRoberts is offline   Reply With QuoteReply With Quote
Old 10-15-2012, 03:38 PM #12
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
I know you are anxious to do something with your third row seats but dredging up old threads expecting a response from posters is not the way. Start a new thread with what you want and see if anyone who is still here answers. It might take a day or two. One of those threads you found was two+ years old!
1engineer is offline   Reply With QuoteReply With Quote
Old 10-15-2012, 03:38 PM #13
BigredTEX's Avatar
BigredTEX BigredTEX is offline
Real Name: Rick
BigredTEX is on a distinguished road
BigredTEX's Avatar
Real Name: Rick
I have never seen a T4R with 3rd row seats in person, but this photo points out some significant differences between a 3rd row equipped vehicle and a sliding tray equipped vehicle. I have the sliding tray and mine looks nothing like this.
First is the 2nd row seats. Do the seat bottoms not fold up and then the backs fold down on a 3rd row vehicle? I assume the thought process at Toyota was if you have 3rd row seats you don't need the 2nd row to fold flat.
Second is the shape of the sides of the rear compartment. Again, I assume it is due to the needs of the 3rd row seat occupants.
Last, to Jtraskell's point about the ridge and the height of the sliding tray in his SR5, the sliding tray is not that tall. It sits much lower - I would guess 4" above the lip of the rear hatch, about where the bottom seat cushions are on the 2nd row seats in the photo.
2012 Trail Edition, Salsa Red, MetalTech (Icon) Long Travel Rear, Panhard Relocation Bracket, Radflo 2.5" Extended Travel Front, LR UCA's, 17x9 XD wheels, Cooper S/T Maxx 285/75-17's (34"), 4.56 Gears, Wet Okoles, Weather Tech FLoor Covers, Canvasback Cargo Covers, Shrockworks Sliders, BudBuilt Hidden Winch w/ Warn 9.5ti, On-Board Air (using sliders as air tanks), Rigid D2's, RCI Skids, Body Mount Chop, Console Vault.
BigredTEX is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 08:00 PM #14
Mindflex Mindflex is offline
Mindflex is on a distinguished road
Thanks,
RC
Know this is waaaay late but do you remember any more details about removing the 3rd row?
Do the seats cone out separately?
How do you get the plastic shrowd off to access the bolts?
Could one person do this or does it take 2?
Mindflex is offline   Reply With QuoteReply With Quote
Old 06-19-2016, 06:05 PM #15
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough
DannyLlama's Avatar
Real Name: Danny
@wvanstone Have you attempted to remove just one? I want to keep just one myself.
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
DannyLlama is offline   Reply With QuoteReply With Quote
3rd row seat , cargo flooring
Finally pulled the trigger!! 2007 Limited T4R mdrudy 4th Gen T4Rs 8 02-18-2011 08:45 PM
Excessive wear on rear tires on 1997 Limited-Any ideas? 4RUNNERTMAN Maintenance/Detailing 5 12-05-2010 10:44 PM
Ideas for adding backup sensor in Limited? DennisW 5th gen T4Rs 1 03-15-2010 05:48 PM
? about replacing carpet with rubber flooring Kmvreter Maintenance/Detailing 0 03-20-2009 01:08 PM
04 Limited audiophile ideas Duc Hunter Engines / Suspension / Wheels / Tires / Audio / Accessories 3 09-29-2004 01:54 PM
