Old 12-28-2021, 07:37 PM #1
swampy_swimmer swampy_swimmer is offline
swampy_swimmer is on a distinguished road
"Reduced Engine Power, PCS off" warning
2020 ORP Only 27K miles.
So I got this dashboard warning: Reduced Engine Power, Pre-Collision system Off, See Dealer" and a beep.
It was there for a little bit, then it went away, then came back. I shut and restarted the truck and it was off.
I have Sprint Booster for over 2 years on the truck and recently installed Start-X remote starter. Also AEM dry air filter. Those are all aftermarket adds that were installed on the vehicle.
I checked the codes with the OBDII reader (basic one, not sophisticated) and everything was clear.
Have someone experienced those warnings? What can case those?
Should I visit dealer till it still under warranty?
swampy_swimmer is offline   Reply With QuoteReply With Quote
Old 12-28-2021, 08:26 PM #2
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Possibly the remote starter affecting the can-bus system.
That’s been documented before.
Best Regards,
Saker
Old 12-28-2021, 08:38 PM #3
Oh, great...
Old 12-28-2021, 09:29 PM #4
Do you think I can drive with it for some time, or should I reverse it ASAP?
Sounds like a silly question, but...
Old 12-28-2021, 09:38 PM #5
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I would remove all the mods and see what happens. If the problem comes back, then take it to the dealer. If you take it in with the mods installed, chances are the dealer will blame them for the problem as other members of this group have experienced in the past.
Old 12-28-2021, 09:42 PM #6
Right. I don't think it's the booster, as I had it for so long without anything going wrong, and the problem started after the remote start install.
Thanks. Good point on the dealer.
Old 12-28-2021, 10:21 PM #7
Saker's Avatar
Saker's Avatar
I can attest to this when my throttle body was throwing a code!
They said it was my SB, then they said it was LED bulbs!
Best Regards,
Saker
Old 12-29-2021, 04:34 PM #8
tifflieger tifflieger is offline
tifflieger is on a distinguished road
Remove one mod at a time, starting with the remote starter.
tifflieger is offline   Reply With QuoteReply With Quote
dealer , engine , reduced , truck , warning
Cold mornings engine "chugs" and check engine light flashes LoxRunner 3rd gen T4Rs 3 12-26-2016 02:27 PM
" (!) " ...type "C" brake warning lamp...?! NYRunner 5th gen T4Rs 11 11-27-2010 05:18 AM
Got the dreaded "check engine" + "VSC off" lights bonedoctor 4th Gen T4Rs 2 11-04-2006 10:33 AM
