Originally Posted by perf0rmance
Did you trying them separately? As in, would the MAF alone give better MPG or the intake?
Regarding pedal response - have you tried a pedal commander? If so, how did that compare?
I ran the intake alone for about 6 months and besides noise under load I noticed no mpg or power change. When the MAF calibrator was installed my mpg change was realized. I don't believe either unit by itself makes a difference tbh.
Just to note the guys at URD have custom fuel mappings pre-installed to the calibrator for your intake / exhaust setup when your purchase. You can always flash these via usb to the unit later if you change your system down the road.
And lastly yes, I had the pedal commander before I modified the intake and MAF calibrator. I ran the PC off after the MAF C install to see the difference. It is noticeable, compared to the PC Id say its like putting the PC in City -2 or -3. Now with both systems I only run the PC in City -2 around town and I find myself accelerating too fast pretty often. Its a great combo although redundant. Nice being able to tune the throttle offroad and when I let someone with a leadfoot drive I tune it down a few notches via bluetooth secretly.
I also bought a throttle body spacer from AFE and Im trying that out now. Absolutely no noticeable changes from the thing but the intake system whistles a bit almost like a turbo
