Old 04-29-2021, 02:21 PM #16
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I have clunks, knocks, ticks, grinds, squeaks, rumbles, sometimes random beeps, they all come around. Best thing to do is check all of the known stuff and do the maintenance like ball joints, tie rods, wheel bearings, shocks, skids, bolts, nuts, etc. then let it go. Otherwise you will spend 200,000 miles trying to find "the noise" instead of enjoying the ride! Some pantera usually fixes it for me.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 03:18 PM #17
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
Originally Posted by lunchboxtheman View Post
Because of what I said about it only happening when changing direction, I suspect my tie rod end ball joints might be shot.
This sounds logical and probable.
BorotHex is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 04:51 PM #18
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
Had the same problem with my front and, clank, pops sounds when backing out from the drive way or pulling into the parking spot with the sharp turns. Solved that problem yesterday. In my case was LCA rear bushings were shot, it was so easy to find out. I would say before do anything check those first. My truck feels like I bought it yesterday brand new.
ax2021 is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 12:17 PM #19
WEAK_E90 WEAK_E90 is offline
WEAK_E90 will become famous soon enough WEAK_E90 will become famous soon enough
how do you "check" those? Visual? procedure?
Jealousy is ugly... Don't be ugly.
Tirdy5's w/ -70 F5's
WEAK_E90 is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 03:08 PM #20
Yes, I can tell when bushings are bad visual just because I had them. But best way to check it with the pry bar on platform . Place the pry bar in between the frame and LCA brackets and try to move it left and right. If bushings are good, won’t be any play. On my truck rear ones had like one inch+ of play and front ones were solid no play at all.
brake , clunk , end , feel , steering
Clunk/knock front pass side over bumps - SOLVED!! ScarfaceT4R 5th gen T4Rs 23 03-09-2023 03:21 PM
Steering clunk... clunk over hard bumps kruegs 3rd gen T4Rs 30 12-12-2017 03:50 PM
Front end clunk, possibly steering rack JBurt 3rd gen T4Rs 2 05-19-2015 02:22 PM
CV replacement, now have a knock/clunk 2StepsAhead 4th Gen T4Rs 12 08-31-2014 10:29 PM
Knock/Rattle in steering column or front end Dustin4185 4th Gen T4Rs 0 03-03-2012 11:17 PM
