04-27-2021, 12:53 PM
Fender Apron Seal Reccomendations
Mine are shot and I'm looking for a good replacement. Could go OEM, but thought I'd ask if anyone else has had good aftermarket luck. Found these, anybody use?
4Runner – Rad Rubber Design – FJ Fender Flaps, Toyota Engine Splash Guards
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
04-27-2021, 01:01 PM
Originally Posted by Jivewalker
Here's two write ups. There are some others if you search:
https://www.google.com/search?client...rubber+designs
rad rubber design replacement engine splash guards
4Runner Engine Splash Guard Replacement, 4Runner Engine Guards
I've run them for about 3 years. Solid product. Good upgrade from OEM. I would definitely recommend
04-27-2021, 01:04 PM
official vendor
official vendor
I have Rad Rubber, but have yet to install them. Great quality product though, and appears to be better than OEM.
Mike
04-27-2021, 01:15 PM
i have rad rubber that hasn't been installed yet.
don't buy anything on amazon, crap quality
not even sure if i can fit the rad rubber. i have secondary shocks hah.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
04-27-2021, 01:43 PM
Real Name: Mark the Common Sense Wizard
Rad Rubber is the way to go. I have them on my 2015 after the OEM stuff tore up. The quality difference is huge, and the protection is definitely worth it.
I'm 007Tacoma. ...well yeah... because we have a... 2007 Tacoma... no a 2008 Tacoma... no a 2003 4Runner er... 2015 4Runner Trail Edition
Check us out at TrailOrSail.com or on our YouTube Channel TrailorSailYT
04-27-2021, 01:50 PM
I also have the Rad Rubber and have had them installed for over a year. These are much better and heavier than OEM and hold up very well. I think these are for sure the best option available currently.
I installed the rad rubber great strong piece I wish they would make fender splash panels as well I would buy it np
Mike
04-28-2021, 09:08 AM
Mike
Mike
Thanks everyone! Looks like Rad Rubber is the way I'll go!
I am fragile.
Not like a flower.
But like a bomb.
04-28-2021, 05:02 PM
Diy
You can make them yourself, if you'd like.
Attached is a template. You will have to print each splash guard on two pages and splice them together to get a full size splash guard.
I purchased the rubber sheet for about $12 on Grainger Industrial Supply - MRO Products, Equipment and Tools
04-29-2021, 07:46 AM
Originally Posted by MAXISTYLES
Now that is pretty cool! What prompted you to go this route? You must work in fabrication of some sort?
I am fragile.
Not like a flower.
But like a bomb.
04-29-2021, 12:50 PM
There was some talk about this same subject years ago and one of the members provided the template. I couldn't find that original thread but I saved the template so I figured I'd share.
I chose this route because It's easy enough to make and it's good to have the template for later use.
