Closed Thread
Old 05-29-2021, 04:50 PM #1
Dahkodah's Avatar
Dahkodah Dahkodah is offline
Dahkodah is on a distinguished road
Dahkodah's Avatar
E locker will not disengage.
Before I rip into this thing, was lubing 4H and 4L with locker. Usually not a problem. Goes in and out easily. Straight away, but on pavement so no wheel slip. I know it's not good practice etc. I've tried backing it out both in the street and on the lawn. Can't get to dirt. It's dragging the rear tires in slow s turns. Front comes in and out of 4H and 4L but rear stays locked. I hear the actuator and it does sound like the gear is moving not straining. The dash light blinks and never goes solid. I pulled the 2 wire connector and the dash light continues to blink and the actuator still sounds the same. Pulled the 5 wire connector and no power to the actuator and the dash light blinks rapidly with the crawl light as well. Connections and wires are in great shape. Plug everything back in and the same happens. With the rear tires off the ground I can rotate them and they go in the same direction, in N and 2wd. I tried driving it about 75/100 yards in 2wd to disengage the locker. Suggestions before I pull the actuator and manually disengage the locker, I hope. I assume if I take that step I can put the actuator back on provided it/O-rings look okay so that I can drive it. I know I should have it in neutral/4Lo and aligned for disengaged to set the timing with the fork. Other suggestions or things I missed. First time with this issue on any gen and have only found info for mostly 3rd gens on the forum. Thanks in advance.
1995 sr5 sold
1998 sr5 gone but may have saved a life
2004 SE sold
2010 TE Dobinsons lift, spc ucas, 35x11.5 Maxxis Razr, XD Storm Sand, rci skids,spod,buncha mods, c4 lo pro smittybilt winch, early 5th hi clearance cut,Lights, pedal commander,Rago panels, spidertrax, shrockworks sliders
Dahkodah is offline
Closed Thread
actuator , dash , light , locker , rear
4 lo won't disengage 06Silver_SportT4R 4th Gen T4Rs 23 09-17-2021 10:12 PM
4wd won't disengage? Bftfan 5th gen T4Rs 14 02-19-2019 01:15 PM
4x4 disengage problem jstevenj 3rd gen T4Rs 4 05-06-2014 11:11 AM
4WD won't disengage, I think patmccrary Problems & Warranty Issues 1 11-24-2009 05:37 PM
VSC disengage by switch Falls Off-Roading 73 02-25-2008 02:56 PM
