Rear Shock Cushion Replacement
ArcticEd
Hi folks -
I got a Radflo 2.5" kit from Overland Warehouse a long time ago. Front coilovers were replaced about 2 years ago after someone ran into my parked truck; rear shocks are still from the original kit.
It looks like the cushions above/below the mounting point have deteriorated and are allowing some movement. I think it's the cause of a clunk I've been getting at low speeds (thought it was the front end, but everything seems solid).
The Radflo shocks come with the cushions (SKU 6ST-001-00) - does anyone know if you have to get replacements from the shock manufacturer or can you use original Toyota/other aftermarket?
I'll be contacting Radflo - just wanted to see if anyone had experience with it.
TIA
