Old 07-08-2021, 11:03 AM #16
djpg2000 djpg2000 is offline
djpg2000 is on a distinguished road
Originally Posted by ElectroBoy View Post
More info could be helpful. You say it’s a 2011. And now you are trying to get new fog lights to work.
Did you buy the 4Runner used?
Did the fogs used to work but now they just crapped out?
Did the fogs ever work since you had the vehicle?
Are the replacement fogs OEM?
I bought it used a few years ago and the fog lights worked perfectly fine. I took it off roading and flooded the engine(yeah I know). Water level was only half way up the wheels but it happened. I was especially pissed since they advertise these things going through water. They had a track set up at the McCormick Place in Chicago for the TRD Pro and they drove it through the same level of water if not higher. Anyway, I had the engine replaced and the fog lights didn't work afterwards. Then, one day about 2 months ago they randomly started working again for awhile. Eventually, I replaced the bulbs with brighter Sylvania halogen bulbs and they continued to work for about a week until all of a sudden they didn't again. Now I'm here troubleshooting..
- 2011 Toyota 4Runner 4.0L V6 4WD Trail Premium Edition w/ KDSS
- ToyTec Ultimate 3" Lift Kit w/ Rough Country V2 Rear Shocks Instead of Bilstein
- Safari Snorkel
- BFGoodrich All Terrain T/A KO2 Tires LT285/70R17 121R E
- 2" Bora Wheel Spacers
djpg2000 is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 11:40 AM #17
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Originally Posted by djpg2000 View Post
I bought it used a few years ago and the fog lights worked perfectly fine. I took it off roading and flooded the engine(yeah I know). I had the engine replaced and the fog lights didn't work afterwards. Then, one day about 2 months ago they randomly started working again for awhile. Eventually, I replaced the bulbs with brighter Sylvania halogen bulbs and they continued to work for about a week until all of a sudden they didn't again. Now I'm here troubleshooting..
Since from your earlier posts it seems like you have occasional voltage at the driver and passenger sides I would first suspect corrosion somewhere causing intermittent electrical connections.
First check at the sockets where the bulbs plug in. See if you can abrade down to shiny metal with a small tool like a sharp edge screwdriver or sandpaper. Then check the wiring harness socket/plug metal in the same way. Every metal electrical interface in that circuit that could have gotten wet needs to be checked, cleaned, or replaced.
Also check for broken wires wherever you can. Wiggle the harness wires around at the fog light socket, push and pull a little when checking the voltages or trying the lights to see if there’s an intermittent connection.
If you got water all the way into your engine fuse box you could have more corrosion in there which would require a lot more disassembly, inspection, cleaning, and replacing. There is a thread in this forum about disassembling the engine fuse box to get at the 140A fuse.
Good luck. Let us know your progress.
Old 07-08-2021, 01:13 PM #18
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Well, I would say that's possible but highly unlikely because the sockets came brand new attached to the bulbs from the auto parts store a couple weeks ago..
We must have a terminology issue here. A bulb consists of the glass portion containing the filament, plus a base that contains the electrical contacts. The fog light housing consists of an outer housing, as well as a lens and reflector. There is an opening in the back of the reflector that the bulb goes into. An electrical harness (wiring) has a plug on the end of it that connects to the base of the bulb.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 02:20 PM #19
1st Picture: What I've been referring to as a bulb.
2nd Picture: What I've been referring to as a socket including and since post #10.
3rd Picture: What I've been referring to as a socket up to and including post #9 and a plug including and since post #10.
Fog Light Electrical Problem-20210708_125004-jpg  Fog Light Electrical Problem-20210708_125022-jpg  Fog Light Electrical Problem-20210708_125032-jpg
- Safari Snorkel
Old 07-08-2021, 03:20 PM #20
#1 & 2 are the bulb. #2 just shows the (male) connector on the bulb - which appears to be in good shape BTW. If you have continuity between the two terminals, the bulb is good since that is a single filament bulb.
#3 is the (female) connector end of the harness - which also looks to be in decent shape. If you have power and ground at #3, your bulb should illuminate. This of course assumes that you have enough tension in the female terminals to make contact with the male terminals in the bulb. If you do not have power and ground here. the problem is upstream.
Old 07-08-2021, 03:43 PM #21
I honestly didn't check for continuity between the two terminals of the bulbs. What I did instead was hook them up directly to the battery via alligator clips and they both lit up which indicated to me that both bulbs are good.
For #3 - Power and ground keeps randomly alternating between the passenger side and driver side plugs. I thought the same thing, maybe the terminals aren't making contact. So, I hooked up alligator clips to the male terminals of the bulbs and made sure the other ends of the alligator clips made contact with the female terminals of the plug. Still nothing which is the craziest part..
Then, I added the temporary ground like you suggested to one side, then the other, then both sides simultaneously and still nothing..
- Safari Snorkel
Old 07-08-2021, 03:50 PM #22
I'm starting to think the guys that replaced the engine messed something up when they did it. The most common problem there is knocking a connector loose, cutting through a wire or forgetting to hook something up. The "wiggle test" - which has already been suggested - can be invaluable here.
Old 07-08-2021, 06:44 PM #23
This is so messed up. I just jiggled all of the connectors and wires that I could see all the way back to the firewall and nothing.
If water got into the fuse box, I'm pretty sure I'd be having much more electrical problems than just fog lights don't you think?
All of the other lights have been working fine (low beams, high beams, turn signals, hazards, DRLs, parking, brakes, 3rd brake, tails, reverse, license plates).
Is the relay/driver side junction box assembly out of the question at this point?
- Safari Snorkel
Old 07-09-2021, 05:05 AM #24
Banned
Real Name: Mark
Banned
Real Name: Mark
Before you attack the relay/driver side junction box assembly, which is the assembly that contains the interior fuse box, trace the continuity of the pins/wires from each fog light wiring harness socket (your pic 3).
Measure the resistance from (left fog) A18 pin 1 to GND, measure resistance from (right fog) A29 pin 1 to GND. Measure the resistance from A18 pin 1 to A29 pin 1. Each measurement should be less than 0.5 ohms.
Find the location of Junction Connector A40 (see pdfs below), and check it. Note whether this was properly connected (after the engine work) and seated. Hopefully this is the source of your problem. If all looks good disconnect it to make some measurements. Refer to the wiring diagram.
Measure the resistance from A18 pin 2 to Junction Connector A40 pin2. Measure the resistance from A29 pin 2 to A40 pin 1.
Measure A18 pin 2 to A29 pin 2. Each measurement also should be less than 0.5 ohms.
Do the wiggle test while checking continuity. Hopefully you will find a loose connector or intermittent wire.
See the enclosed pdf for the location of Junction Connector A40, A18, A29.
If you haven't found the problem by now you should check continuity between A40 pin 5 to the relay/driver side junction box assembly at connector 2D pin 9.
This will be more involved in order to access that connector.
Old 07-09-2021, 01:41 PM #25
Thanks for spelling this out for me because I am by no means an electrician. But, I can follow directions..lol
I will update you guys on the results when I have them.
- Safari Snorkel
Old 07-09-2021, 02:06 PM #26
flyrv9's Avatar
flyrv9 flyrv9 is online now
flyrv9's Avatar
A couple of thoughts: I'd check both the plug and socket sides of each bulb and it's connector to see they are in good shape and fit tightly together. Tug the wires and see if they are solidly connected. Take a meter on the ohms scale and measure the resistance of each bulb. The value should be close to a short (maybe 1-2 ohms). They should also be very close to the same value.
The type of bulb in your pic should be clean and free of fingerprints. Clean with alcohol if dirty and then don't touch the glass part. Use a lint free cloth for cleaning and handling. The reason is the oil from your hands and other places gets on the glass and creates hot spots when the bulb is on, shortening the life of the bulb.
As far as troubleshooting goes, I'd make a chart to record my actions and results, and values. This helps over time to keep things straight and allows you to compare left and right sides.
flyrv9 is online now   Reply With QuoteReply With Quote
Old 07-09-2021, 04:39 PM #27
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
this is unlikely because it's not typically how bulbs burn out, but it is something that can happen - when you tested the bulb did you shake it?
it sounds silly, but before you spend time checking electrical make sure the bulb doesn't have a broken filament. on rare occasions the filament can break but be touching in a resting condition to turn on.
again, this is not likely, but i've seen it happen before and ever since i shake bulbs when i test them
jhguth is offline   Reply With QuoteReply With Quote
Old 07-09-2021, 07:41 PM #28
Found the culprit. I didn't get any continuity between A40 pin 5 to the relay/driver side junction box assembly at connector 2D pin 9. So, I started checking the wire and saw that it had been spliced into. When I looked at it more closely, I saw a ton of corrosion all over the wire (pictured below).
Here is why it was spliced into:
When I first bought the truck used. The previous owner did the DRL Fog Light Mod. I hated it and reversed it because I wanted to be able to turn them on and off at will. Apparently, moisture got into it somehow and corroded the crap out of it. I cut out the corroded part of the wire, installed a new wire, and now the fog lights work perfectly.
I really want to thank everyone for all of your help. I know this stuff is a pain in the ass to diagnose and even worse to diagnose over the internet. So, I really do appreciate all of your help. I most likely would not have come to this conclusion without you. I would have probably ended up wasting a lot of money having somebody else do it for me. Thanks again!
Fog Light Electrical Problem-20210709_171519-jpg
- Safari Snorkel
Old 07-09-2021, 08:56 PM #29
Banned
Real Name: Mark
Banned
Real Name: Mark
Good job, you found the problem and repaired the corroded connection. You had a good start getting the wiring diagrams and figuring out some of the pertinent circuitry.
For a suggestion, whenever I make electrical mods I always solder connections, insulate with shrink tubing and overlay it with liquid electrical tape or black E6000 adhesive to keep it watertight.
Now enjoy your new fog lights!
Fog Light Electrical Problem-ad44746f-b4c4-4723-a65b-e23c1bb2fb6d-jpeg  Fog Light Electrical Problem-b4ea63a7-d20e-46ef-8725-874954d7acb3-jpeg
Old 07-09-2021, 09:52 PM #30
Thank you man! I will definitely be using that method. I'll probably redo it soon but I just wanted to make sure it worked and kept on working for now..lol. Thanks again!
- Safari Snorkel
assembly , box , coming , junction , power
Electrical problem - Please help!! bobdod04 4th Gen T4Rs 21 11-05-2021 06:02 PM
clock and map light electrical problem MacGyver1979 Classic T4Rs 0 10-13-2015 01:10 PM
I have an electrical problem Jamie223 General Discussions 9 01-01-2015 12:04 PM
Gauges/Power window/Reverse Light Electrical Problem brettniles Classic T4Rs 0 10-04-2013 06:14 PM
Need help with a Electrical problem Bearcat5150 3rd gen T4Rs 2 08-27-2012 11:49 PM
