Old 07-21-2021, 08:51 AM #1
BADCLOWN's Avatar
BADCLOWN BADCLOWN is offline
BADCLOWN is on a distinguished road
BADCLOWN's Avatar
KMC wheels: user reviews?
Anyone running KMC wheels on their T4R?
What’s your opinions of them (good, bad, and the ugly)
2017 Toyota 4Runner TRD Pro Cement Gray - OE blackout badges, Innovativ HIDs, OE LED fogs, AJT, black TRD shifter, 33inch light bar, K&N, CanvasBack, Toytec 2 inch lift, 34 inch tires, 2021 TRDP wheels, URD
BADCLOWN is offline   Reply With QuoteReply With Quote
Old 07-21-2021, 01:01 PM #2
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
I've been running the KMC KM717 Bully OL's 17in 0mm offset. Love them. They're lighter than most wheels out there and fairly inexpensive as well. Have always loved the Bully spoke pattern as well, so was stoked when they came out with the OL version.
They have the same tech as the Method Bead Grip series, so they hold the bead on better at low pressures. KMC calls that the OL (over lander) series.
They just came out with a Made In The USA model called the Impact OL's that look great as well.
KM717 Bully OL
Impact OL
KMC wheels: user reviews?-2021-04-23_07-18-42_339smaller-jpg  KMC wheels: user reviews?-2020-06-25_20-10-10_170-small-jpg  KMC wheels: user reviews?-4r-fins-n-things-1-jpg  KMC wheels: user reviews?-impact-ol-jpg
dezertbomber is offline   Reply With QuoteReply With Quote
Old 07-21-2021, 02:27 PM #3
Saw that the new Impact OL's come with either 0mm or -12mm offsets. The -12mm increases the weight a little to 28lbs (0mm is 25lbs).
Old 07-21-2021, 03:46 PM #4
BADCLOWN's Avatar
BADCLOWN's Avatar
I REALLY like the SUMMIT and TREK models in the flat black outer/gray center finish.
I will need new tires (OEM ones finally going out) and would like a wheel that sits out farther without having to run a 1.5 spacer like I would have to with the OE wheels/larger tire set up.
Old 07-21-2021, 06:01 PM #5
Summit's have a 0mm offset like my Bully OL's, which push them out a little, but I still added 1.5in spacers to get them out a bit more.
The Trek's have a -12mm offset option, which would prob be good to not need a spacer, but you'd have to see once you get them on.
Old 07-21-2021, 07:01 PM #6
BADCLOWN's Avatar
BADCLOWN's Avatar
My brother threw 285s on his stock TRDP wheels and tried out 1.5 spacers and said he developed fairly bad steering wheel shake with them on. Took them back off and had no issues.
If anyone has the -12 offset KMC wheels on their truck and can post some pics here showing fitment that would be great
Old 07-21-2021, 07:38 PM #7
The spacers wouldn't cause that unless something was not tightened evenly. Like I said, I run 0mm offset and 1.5in spacers, zero issues. Drove the 3hrs to Joshua Tree, bombed pretty hard, and back with no problems. Checked all 24 lug nuts' torque, all fine. Then did 2,000+mi Utah overlanding trip a couple months ago and still all good.
These are the spacers I got. I recommend buying the ET (extended thread) lug nuts for them as well: Amazon.com: KSP 6X5.5 Wheel Spacers Fit for Tacoma 4runner, 1.5 inches Forged Hub Centric Adapters Kits fit 6 Lug Wheel Without Locking hub, Package of 4, (B07DLX519N): Automotive
Old 07-22-2021, 02:58 PM #8
BADCLOWN's Avatar
BADCLOWN's Avatar
He’s a competent truck owner and had everything tightened correctly. Vibrations went away when he removed the spacers. Who knows.
What is the recommended tire size for a 17x8.5 tire?
Also, if you run a 0 offset 8.5 wide wheel with the recommended tire, will that require any body modifications?
Old 10-22-2021, 10:05 PM #9
BADCLOWN's Avatar
BADCLOWN's Avatar
Bumping this up, still looking for pics of these on 4Runners
Old 10-27-2021, 11:19 AM #10
HGAdv HGAdv is offline
HGAdv will become famous soon enough
I bought a set of the KMC 17x9 Chase wheels and have been very happy with them.
Here they are with Toyo MT’s , without rubber and with a set of Nitto Exo Grappler AWT for the winter months.
HGAdv is offline   Reply With QuoteReply With Quote
Old 10-27-2021, 12:16 PM #11
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough
DannyLlama's Avatar
Real Name: Danny
I had a set early on and they worked fine. I ended up changing to FN and now Methods. But only due to style and size.
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
DannyLlama is offline   Reply With QuoteReply With Quote
Old 10-28-2021, 10:06 AM #12
KM717 Bully OL
Impact OL
the blue terra's look awesome.
Old 10-28-2021, 03:13 PM #13
WOLFN8TR's Avatar
WOLFN8TR WOLFN8TR is offline
WOLFN8TR is on a distinguished road
WOLFN8TR's Avatar
Hey Jacob whats up! Man there is a bunch of BMW guys on this forum.
2015 Toyota 4Runner Trail
WOLFN8TR is offline   Reply With QuoteReply With Quote
bad , good , kmc , opinions , wheels
New user mamukaok New Members 5 11-06-2013 12:07 AM
new user flow 4th Gen T4Rs 5 01-27-2008 02:59 AM
user name pic's kraftwerkauto 4th Gen T4Rs 2 08-28-2007 12:24 PM
User Name Randy Arnold Comments & Suggestions 0 11-29-2005 08:46 PM
new user here and 1st ? Joachim2311 Maintenance/Detailing 2 07-06-2004 08:46 PM
