Old 04-13-2022, 10:58 PM #1
Logansky Logansky is offline
Logansky is on a distinguished road
Advice needed install of TRD skid plate
I finally got around to installing my skid plate. Watched all the you tube videos, cleaned out the threads, did everything right. Did it with vehicle on ground, stock TRD Off Road suspension. Tight but manageable.
EXCEPT I had a heck of a time man handling it into position and starting the bolts. Sort of dreading the next oil change when I have to remove it and do it all over again.
Any suggestions or little tricks to make life easier would be greatly appreciated.
Logansky
Logansky is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 12:35 AM #2
Something_Awesome's Avatar
Something_Awesome Something_Awesome is offline
Something_Awesome will become famous soon enough
Just going from memory, this video may help you.
https://www.youtube.com/watch?v=cUPU...aEzfq&index=14
I believe he mentions something about the plate toward the end of this video... at the end of the oil change.
Something_Awesome is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 01:34 AM #3
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
Logansky
Ensure you use the retainment washers on top of the spacers for the front bolts. I also use an impact so it can spin while I hold the skid in place with my other hand and knees. After you do it twice you get the routine down.
dezertbomber is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 10:07 AM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Logansky
Replace the bolts with studs. Makes it much easier to drop the skip plate for oil changes. This thread tells you how: TRD Skid Plate Mounted w/ Studs 2010-2021
I did this a couple weeks ago and it makes a big difference.
fkheath is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 07:02 PM #5
Beach5150 Beach5150 is offline
Real Name: Tom
Beach5150 will become famous soon enough
Real Name: Tom
I just installed mine about a week ago.
Same, stock height & on the ground.
I just balanced it in a floor Jack and adjusted it as I lifted it into enough position to get the rear bolts stared. Was easy after that.
I actually had to do it twice. A factory defect causing one of the radiator support brackets being too low where you remove the bolt at the radiator end. A mount nipple was too low preventing me from starting the bolt. Some factory robot probably had no problem forcing. But I had to grind off the nipple to get it to go up. No fun!
It would be a pain doing that for self oil changes. But I’m a worn out, used up 67 year old & have it done.
A white 2017 Off-road for me, and a Cement 2020 Tacoma Off Road for the wife.
Beach5150 is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 07:24 PM #6
Saker's Avatar
Saker Saker is offline
Saker's Avatar
@fkheath
Thanks for the suggested link !
@Logansky
I created this mod for people like you and I.
I used to fight my skid. After talking to other members about the same, I decided to create a solution to the problem.
BTW, even it you don’t do the mod, I would refrain from using an impact wrench on these skid bolts.
Use a floor Jack to Jack it into place. Align & start bolts with your fingers.
Best Regards,
Saker
Old 04-16-2022, 02:19 AM #7
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
as long as you use the two bolt clips on the front bolts, you can sit on the ground and use your knees to support the skid plate to remove and install. Once the two front ones are hand turned, the rears can be installed easily
daytonaviolet is offline   Reply With QuoteReply With Quote
change , oil , plate , skid , trd
Skid plate advice cl4Rk 3rd gen T4Rs 20 12-02-2021 09:59 PM
Help needed from Toyota TRD Pro skid plate owners carlodonz 5th gen T4Rs 3 09-01-2020 09:36 AM
Front Valance/Skid Plate Help Needed apache67 5th gen T4Rs 1 07-27-2020 11:05 AM
*WTB: FJ (Bling) skid plate mounting brackets needed! Anyone? MojoRunner Want to Buy/Trade 0 10-30-2014 11:15 PM
Skid plate most needed...Front or belly pan? 96KYRUNNER 3rd gen T4Rs 6 02-08-2014 03:59 AM
