08-09-2021, 11:46 AM
Lost something down tool access panel...how can I retrieve?
I was storing something small in the tool access panel in the back of truck, anyways it fell down past the metal supports that hold the tools and jack, and now who knows where it is, is there any way to access this area?
08-09-2021, 12:47 PM
There is an exhaust vent under the bumper cover that you can pop out.
08-09-2021, 03:24 PM
Mechanic's magnet
08-09-2021, 07:39 PM
That entire lower panel can come out. I had to mostly remove it when replacing my rear seat belts. It's ~5 screws and then 5-10 retaining clips that will simply pull out with enough pressure/force to get the whole things out. You probably dont need to remove the whole thing. Just enough be able to move it and to locate the escaped tool. Start from the back near the hatch. You may have to peel back the weatherstripping a bit to gain access and start popping out the pressure clips. It was very easy/straightforward. Could do it again in less than 5 minutes if I had to.
The reference thread I used is here.
Seat belt replacement
08-09-2021, 09:02 PM
I took off the exhaust vent and the drain plugs underneath to fish out what I dropped down there. PITA
Probably faster to remove the panels inside looking back at it.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
08-09-2021, 10:16 PM
Originally Posted by CutthroatSlam
Mechanic's magnet
what drugs are magnetic???? asking for a friend (DEFINITLY NOT THE OP)
08-10-2021, 09:51 AM
LOL, I assumed it was sort of nut or bolt because that’s what I always drop while working on them. I jumped past the “storing something small.” I do hope he gets his medical marijuana out of there.
08-10-2021, 01:22 PM
I lost a wheel lock key down there, it's still hanging out :X
2017 T4R TRD Pro Cement - Dobinsons 2/1" (300/599), IMS 700/701, Air Lift 1000 air bags (60804), Pelfreybilt hidden winch mount, Warn VR8 w/ Amsteel synth, 2021 ORP LED headlights, DD SS3 Sport yellow fogs, CBI steel skid plates, Rough Country 20" LED bar, Gobi stealth no rise w/ ladder, ARTEC sliders, ARB 63qt fridge, Canvasback liners, homemade spare tire hitch carrier, ARB single air compressor w/ Slee mount, bronze TRD Pro wheels
08-10-2021, 02:07 PM
he was smugglign covid vaccines
08-10-2021, 03:00 PM
old pantyhose slipped over a vacuum like a condom.
08-10-2021, 08:26 PM
? theyre literally paying people to take that
08-11-2021, 01:21 PM
that's a great idea, but I don't know anyone that wears panty hose any longer or if you could ever buy them.
I know if a store has them, I wouldn't buy them and don't want that in my Amazon history either
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
10-21-2023, 09:25 PM
I know this is an old thread but this happened to me this week. Still haven't solved it and it's driving me bananas. Lost two locking lug nuts down there. So I tried the panel removal thing with no success because they rattled down the deep dark recess to the rear of the metal plates and sound like they settled somewhere forward. I didn't seem to be able to get below the metal supports/plates even by removing most of the panel.
Magnet didn't work because the whole damn thing is metal so the magnet goes nowhere.
10-22-2023, 08:22 PM
go to around 6 minutes in this video. maybe you can get your hand in going through the storage tray area. this guy shows how to remove the trays. probably easier than trying to go through the access cubby
Adding constant power to rear of 5th Gen 4Runner - YouTube
