Originally Posted by dakgildea
I don't have the white wire plugged into anything currently. I have all the wiring under the hood and not under the dash as that's where the control panel sits. First I had the white wire on an add-a-fuse to the trailer tail light fuse but the backlight would stay on even when the truck was off. Tried to then move the add-a-fuse to the Dome fuse. Same thing, backlight stays on. Is it possible to add-a-fuse for the white wire? It's already cut so I would need to extend it if I need to t-tap into something. As stated above, it's pretty darn bright.
What I did: add a fuse to connect the white wire with the “tail light” fuse, bottom on the left of the interior fuse box. The tail lights come on with both the parking lights and the headlights, so works perfectly for dimming when lights are on. I could not find anything in the engine fuse box that worked.
Note, I'm 2019. Not sure if the fuse box was changed in 2020+ but this works for previous years.
