03-14-2023, 09:52 PM
#76
So I finally finished up my upper and lower grille mods. Pics of grilles with mesh attached. I also painted the Toyota symbol to color-match the truck.
I made a bracket and installed Diode Dynamics lights in the lower grille area. I added two small red lights in the upper grille area.
And finally with the bumper back on:
Pretty happy with how it all turned out. Still need to wire up the lights.
Also, You'll notice that I have cut away the lower portion of the bumper. I am designing and will soon start building a winch bumper.
Bandit Runner, 2021 TRD Off Road Premium
Build Thread: https://www.toyota-4runner.org/5th-g...ild-2-0-a.html
03-16-2023, 12:20 PM
#77
Real Name: Jeff
Real Name: Jeff
That looks great. I'm excited to see what you came up with for a bumper. I think your 3rd gen's was great.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
03-16-2023, 12:31 PM
#78
How did you attached the mesh?
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
03-17-2023, 10:00 AM
#79
I had to epoxy some chunks of plastic around the backside perimeter. Then used small screws to attach the mesh to those plastic pieces.
It was actually quite a bit of work making sure everything fit correctly.
03-26-2023, 09:35 PM
#80
Looking good!
03-29-2023, 09:35 PM
#82
Real Name: Jeff
Real Name: Jeff
I've gotta say that's the best 5th gen bumper I've seen. Well done man.
Build
03-30-2023, 09:27 PM
#83
Thank you sir! Much appreciated.
04-28-2023, 05:08 PM
#84
Cool build!
I liked your 3rd gen. I’m copied your roof rack for my 3rd gen. I had to sell it a few yrs back. But I’m back with a ‘22 ORP in Barcelona. I dig the mods. How are you liking the light setup?
`73 Ford Courier-40’s all Toyota underneath
‘22 ORP-DD-mild build
`05 Cummins...tow pig
Sold-‘98 Runner 4Runner Build
05-08-2023, 09:42 PM
#85
Originally Posted by Jedrattle
Cool build!
Thanks. For the little bit I've played around with the lights, I like them so far. Will be doing some camping soon and hope to really put them to use and see how they do.
05-09-2023, 09:27 PM
#86
Making some progress on the front bumper:
05-20-2023, 10:03 PM
#87
A little more progress on the front bumper:
Center section is basically done, just need to clean up the side edges yet. Then move on to the side wings.
05-21-2023, 01:35 PM
#88
this is awesome.
07-17-2023, 09:20 PM
#89
Well I finally finished all the fabrication on the front bumper. It took way longer than I expected, but I think it turned out really nice.
I also made a small skid plate that bridges the gap between the bumper and the OEM skidplate:
I just need to clean up a few things, and then get it off to the powder coater. Can't wait to finally get this thing installed.
07-17-2023, 10:22 PM
#90
Real Name: Jeff
Real Name: Jeff
Let me be the first to say: hot damn! That's a good looking bumper!
Build
