trd pro grill options
osugsxr
Looking for the TRD pro grill for a 2017
Will the 2020 /21 parts fit 2015-2019 editions, seems the new parts are tad cheaper
$287 Garnish Front Bumper PZ323-35058
$113 Grille Radiator Up PZ327-35056
There is no difference that I could tell between my 2021 and my 2018 and I have had both apart numerous times. All clip positions are identical.
From what I understand, the newer versions have a slight notch cut out for the Toyota Safety Sense. You should be able to use it, it will just have that cutout unfilled, but it is on the bottom so you may not see it much.
I know about the safety sense. I do wonder the actual difference between the two and would like to see them side by side. The new version is tad cheaper too, if its just a small notch and not noticeable then no worries
An $8 can of matte black Krylon fusion, some careful taping and a black overlay for the chrome emblem and you are all set. Embrace the SR5-ishness.
top mesh has different mounting. The metal bracket in the middle won't line up correctly. I used a 2018 on my 21. Didn't want to return it, so I modified it to work. You'd have to shave down some plastic on the upper mesh to make the metal bracket fit properly.
