Locking hitch pin that isn't junk?
thirteen
This should be an easy thing to find, but every pin I look into has horrible reviews everywhere. Is there a good, reliable locking hitch pin anywhere? I realize that anyone who's an expert thief will always be able to pick any lock, I'm just looking for something with decent build quality that won't stop working after some road dust gets on it.
I've read 850 reviews here and other sites, purchased 5, and I still can't find on that doesn't suffer from some or all of these problems:
  • Rusts
  • Lock siezes over time
  • Rattles in the hitch
  • big and awkward design that look odd
It's really only a problem if you are trying to keep something at all times, which I am.
There's a huge market for someone that designs a great locking hitch pin.
Maybe we should as Apple to do it ...
  • Rusts
x2 man I hear you. I looked for days. nothing I liked. you could use a 5/8" grade 8 (I think it's grade 8) stainless steel bolt, washer and lock nut.
I have been using the Reese tactical lock and surprisingly it has not rusted and the lock mechanism still works (surprisingly I know). I've had it for a few months now. I will see how it holds up over the next 6 months
for anyone that doesn't need a locking hitch pin B&W makes a great stainless steel one. I have that one and it doesn't lock. It's been on in all weather conditions and still no rust (but it's B&W they are quality and $$$). Kind of off topic, but hitch locks are very easily defeated. anyone with a pipe or prybar or power saw can break them off, very easily. If you run a hitch tightener that is more likely to deter a thief than a lock. you'd need a ratchet to remove it, if someone is walking around with a ratchet set to steal hitches they will certainty be prepared to break a lock off. for what it's worth, when my reese lock fails I will just snap it off and go back to my B&W unlocking pin I like it so much
also side note. I used two grommets on the receiver lock cylinder to stop it from rattling side to side movement in the hitch
EDIT: out of curiosity I went to unlock my hitch pin to inspect it. I turned it upside down after removal and water dripped out the keyhole. cannot recommend the reese product unfortunately. it wouldn't last 1 month in the winter without rusting. too bad, I liked that hitch pin. back to my B&W pin I guess
i have a locking hitch pin that you actually thread in to avoid the loose connection and had a lock on it. there's actually a big square nut you have to insert inside the hitch and tighten it with a wrench. i'm not sure if it's still being sold at etrailer.com.
check this out. Attention Required! | Cloudflare
something like this?
if you live somewhere with winter conditions be careful that the nut doesn't rust itself inside the hitch tube. I've heard of that happening and people having a hard time removing them because the bolt is threaded
I just bought a replacement after 10+ years.
It gave me such good service, I went with the exact same one!
Durasafe Stainless Steel Receiver Lock - Tackle Warehouse
If you use a locking pin, also buy a good drill and several bits, a 5lbs hammer and give yourself an extra 30min before you try and use it. Been there 3 times.
Exactly what I'm trying to avoid. I looked up most of the pins recommended in this thread and I see so many reviews saying they are crap. I'm starting think there is not a good one anywhere.
I’m only giving feedback because the DuraSafe I listed lasted and worked well. I wouldn’t have posted otherwise.
YMMV
YMMV
Thanks for your suggestion. I actually did not see any real reviews for that one. Just someone saying it did not fit their Tacoma. Maybe that's the one I should try. It's really not that important that I have to replace some cheap pin every couple of years. I just don't want to be stuck somewhere needing to get it off and the key won't work.
With the offerings, I would consider using a stainless steel bolt and two nuts followed by cranking the sucker on good and tight.
