Old 11-11-2021, 02:17 AM #16
thirteen thirteen is offline
thirteen will become famous soon enough
Originally Posted by michalik.piotr6837 View Post
If you use a locking pin, also buy a good drill and several bits, a 5lbs hammer and give yourself an extra 30min before you try and use it. Been there 3 times.
Exactly what I'm trying to avoid. I looked up most of the pins recommended in this thread and I see so many reviews saying they are crap. I'm starting think there is not a good one anywhere.
thirteen is offline   Reply With QuoteReply With Quote
Old 11-11-2021, 03:32 AM #17
Saker's Avatar
Saker Saker is offline
Saker's Avatar
I’m only giving feedback because the DuraSafe I listed lasted and worked well. I wouldn’t have posted otherwise.
YMMV
Best Regards,
Saker
Old 11-11-2021, 04:11 AM #18
YMMV
Thanks for your suggestion. I actually did not see any real reviews for that one. Just someone saying it did not fit their Tacoma. Maybe that's the one I should try. It's really not that important that I have to replace some cheap pin every couple of years. I just don't want to be stuck somewhere needing to get it off and the key won't work.
Old 11-12-2021, 08:57 PM #19
????? ????? is offline
????? will become famous soon enough
With the offerings, I would consider using a stainless steel bolt and two nuts followed by cranking the sucker on good and tight.
????? is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 11:55 PM #20
Jeremy556's Avatar
Jeremy556's Avatar
Which are now galled into being unremovable without destruction, just like most locking pins.
Old 11-13-2021, 12:00 AM #21
Jeremy556's Avatar
Jeremy556's Avatar
Originally Posted by rageandlove View Post
There's a huge market for someone that designs a great locking hitch pin.
Maybe we should as Apple to do it ...
We'll all be lining up to buy the $800 locking hitch pin that comes in a fancy box and unlocks based on facial recognition, secured an an electromagnetic locking mechanism, which eventually only locks for short periods of time after a software update.
Old 11-13-2021, 01:39 AM #22
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Weird there isn't a bombproof solution for this as lock pin becomes another weak link if you're using a shackle for a recovery point. I have a first gen Factor 55 shackle mount but I have avoided using it for recovery for this reason. I'm leaning towards an oversized ultra-grade bolt and nut. On the other hand, maybe the shear strength of good quality locking pin is enough. bottom line - Don't skimp!
Old 11-13-2021, 10:35 AM #23
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
If you build a ten foot wall to protect yourself from thieves, they just buy an eleven foot ladder.
Fortunately, I live in a very rural area and don’t need a locking pin. But I do have one. Both pins are only in place for the duration of my towing needs, which is generally only hours. Both are stowed in a tote inside my 4Runner.
My locking pin is simply a cheap Harbor Freight pin, which I’ve had several years. I don’t think it’s ever seen a raindrop or snowflake, so I cannot comment on its durability. Being a Harbor Freight item, I doubt it has any durability. But it’s worked for me.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 11-13-2021, 02:43 PM #24
jmcelroy jmcelroy is offline
jmcelroy is on a distinguished road
Don't forget that it only works with stingers from the same manufacturer so you can throw all your existing 2" hitch parts away.
jmcelroy is offline   Reply With QuoteReply With Quote
hitch , locking , pick , pin , road
Locking trailer hitch pin issue xwake4lifex 4th Gen T4Rs 3 11-15-2018 09:25 PM
Locking hitch receiver pin recommendation? GrantK 5th gen T4Rs 10 04-24-2013 07:44 PM
Locking Hitch/Bracket and Shackle Options? FireEngineer 4th Gen T4Rs 9 03-04-2012 04:00 PM
STUPID 3.0 head gasket!! JUNK JUNK JUNK!! Jamesd Classic T4Rs 16 02-13-2011 03:46 PM
