01-17-2022, 06:10 PM
#16
Originally Posted by Bmnorm2
Spend the $35 if you want, but i don't know what you would do with the information. Say the results show huge amounts of wear metals and bearings are shot. What would you do with the information? Replace all of the bearings?
I suggest that based on the high probability that the results would show nothing abnormal and give him "peace of mind".
If there was tons of bearing wear which i agree is not likely, I would want to know.
and like you said, most contaminants that cause wear come from the intake and poor air filtration. In "theory" all internal moving parts are all separated by a film of oil, so there should be no wear items (metal etc) that just flakes off.
Contaminants are mostly introduced through air filter / vacuum leaks and fuel system.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
01-18-2022, 01:16 PM
#17
Originally Posted by Ripper238
Not so worried about the wrong filter, but 17k between oil changes and the wrong filter.
Please tell us you were using synthetic.
He was on the third filter at 17k. First filter ~7k, 2nd filter ~10k, 3rd filter ~300 miles. So it was three of the wrong filter before the issue was caught.
Yea, if $35 is not a big deal for his budget, it wouldn't hurt to have "peace of mind". If there aren't any obvious new noises, oil burning, or other signs I still think it's pointless and he should just move on and use correct filter in future.
There is some disruption of the hydrodynamic oil layer during operation, particularly on cold start up. Additionally, there is a decent amount of wear metals on a new engine as parts wear to fit.
01-19-2022, 07:15 PM
#18
Thanks for all the info guys.
I am not going to worry about it.
If I didn't stretch the last oil change to almost 10K I would not care one bit. Still I dont think it is a big deal at all even with the screw up. Most of my miles are highway so that also helps.
2015 Magnetic Grey Limited with Redwood interior. 275/55r20 Michelin Defender LTX on stock wheels. Daystar 2.5/1.5 puck lift.
Gone but not forgotten: Black 2000 SR5 "Highlander", Supercharged, Black pearl emblems, Factory e-Locker.
11-18-2022, 08:49 AM
#19
My buddy Sean had his first oil change at the dealer, since it was free. He did the second one and found that they had used a short filter too.
I seriously detest changing the oil on my 5th Gen. 4th gen took 15 minutes. 5th gen - an hour or so.
Steve
2018 4Runner - TR'aD Off Road - Old Man Emu shocks/springs. OPOR Slider
1989 4Runner (490,000 miles and sadly sold)
2004 4Runner (now at 285,000 mi. and sold)
2000 Celica GTS - the little bro with an attitude - speed limits toooooo loooow
11-18-2022, 09:43 AM
#20
youre fine. takes more then that to kill a toyota motor.
11-18-2022, 10:31 AM
#21
I can sympathize with you. A Toyota dealership did the same thing to my brand-new truck. It came with free oil changes, and it was freezing cold in the winter I felt stupid not taking advantage of the free services, although I usually do all my own maintenance. It probably went 4K with this configuration circulating partially unfiltered oil.
I complained loudly, but the stealership wouldn't give me any concessions like an engine warranty or anything. They offered me like six free more oil changes
I plan on keeping this truck until it or I die, so it will be interesting to see how it plays out. Wishing you the best for your engine.
11-18-2022, 12:52 PM
#22
It sounds like he went 7K on the first short filter, 10K on the second, and noticed the problem when installing the third.
2019 TRD ORP. BFG KM3 285/70R17. Hefty front tube bumper, LFD dual swing-out rear bumper. Warn Zeon 10S. RSG sliders. Sherpa roofrack. Goose Gear interior. Radflo 2.5 suspension.
11-18-2022, 07:02 PM
#23
Now I’m wondering if I should ask for my used oil filter when I get an oil change to make sure the right filter was installed.
11-18-2022, 09:49 PM
#24
But you wouldn't know until 5000 miles later...
11-19-2022, 12:57 AM
#25
Maybe I should just bring own then just to make sure.
11-19-2022, 08:07 AM
#26
When I was in high school, brought my dad's camry to the dealership for an oil change. I asked what type of oil do you guys use? Service manager said, "We use 20W-50 in all oil changes". The camry calls for 10W-30 on the cap. Needless to say I learn to do all basic maintenance myself then on.
11-19-2022, 11:36 AM
#27
Don't trust Amazon
There are certain things I would never trust buying from Amazon. This is one of them.
11-19-2022, 05:11 PM
#28
Real Name: Rich
Real Name: Rich
I've bought mine from Amazon but I buy them from dealerships, not parts places. I've got a 1999 Sienna and 2004 V8 T4R, never had a problem. I buy a half case at a time.
On the other hand, I bought one for the Sienna from the local dealership. 5,000 miles later I took it off and it was bone dry, filter element totally clean. I'm guessing the ball device that prevents back flow draining was stuck for both directions. So you never know. Stuff happens.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
08-28-2023, 06:48 PM
#29
This same exact thing happened to me. Against my better judgement I let the dealership do the 10k oil change because it was free. (I had done it already at 5k) When I did it today at 15k I realized the shorter filter had been installed. I knew I shouldn't have let them change it .. never ever ever again will they touch my truck. Im sick over this but at least mine was only for 4,800 miles on a new truck.
08-28-2023, 07:20 PM
#30
So, I would inquire as to the reason they didn't install the filter by application!
Toyota Part # 04152-YZZA5
Just sayin'
Best Regards,
Saker
