Old 03-13-2021, 03:24 PM #1
RidgeRunnin's Avatar
RidgeRunnin RidgeRunnin is offline
RidgeRunnin is on a distinguished road
Oil Change, Stuck Filter Drain Plug, Solution?
Hello All, I was hoping someone wouldn't mind being a guinea pig for a little tool i mocked up last night.
My Oil filter housing drain plug (Red Arrow) was stuck on at my last oil change and out of fear of cracking the plastic housing in a vice, i just left it on without changing the gasket under it(this time).
With that said, i made a model of a filter wrench with a through hole so in theory you should be able to hold the filter housing steady and crack loose the metal plug.
If someone is bored and has an oil change coming up i would appreciate and feedback on the design so that i works at my next change
When i do find the time to drop the skid plate and fit check the tool i'll update.
Link to both the .stl and .stp are below.
Free CAD Designs, Files & 3D Models | The GrabCAD Community Library
Oil Change, Stuck Filter Drain Plug, Solution?-oil_filter_drain-jpg  Oil Change, Stuck Filter Drain Plug, Solution?-file_002-jpg  Oil Change, Stuck Filter Drain Plug, Solution?-file_000-jpg
2018 TRD Off-Road
RidgeRunnin is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 04:08 PM #2
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
Looks like a great solution!
I have a 4th gen, with the “old fashioned” oil filter, so I can’t be your guinea pig.
2004 Limited V8 4WD 184k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 04:25 PM #3
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
This exactly why I love being able to do cost effective rapid prototyping! Twenty years ago it would have cost you over a thousand bucks and three weeks of waiting to make that.
Great idea. thankfully, I haven’t run into the issue. regardless, this is a perfect solution for it.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 04:31 PM #4
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Or you can use the vise grip style oil filter pliers. Just saying.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 04:35 PM #5
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
I change my 4runner's oil every 5000 miles right in my driveway. Definitely don't want that drain bolt locked on so you can't get it off - or you strip something.
The filter should be hand tight and 1/4 turn further.
FordF150 is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 05:03 PM #6
00Sebby's Avatar
00Sebby 00Sebby is offline
Real Name: Mark
00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice
00Sebby's Avatar
Real Name: Mark
What you said is true for standard one-piece spin-on filters since the gasket has to be compressed enough to seal the oil in and not overly compressed that the gasket squishes out and leaks.
However, these cartridge filters have to be turned until they bottom out against the mating part... like a dead stop. Hand or wrench doesn't matter, but you turn to fully-bottomed condition vs. turning to the subjective tightness of a spin-on filters. The only reason I am pointing this out is with "hand tight + 1/4 turn" someone could think it's tight enough without it being fully rotated in and it could leak later.
And even though it's a simple concept, every dealer and quick change place will still over-torque these housings and make it almost impossible to take off without damaging or breaking them.
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
00Sebby is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 05:03 PM #7
jrandom's Avatar
jrandom's Avatar
Or you could use an impact wrench, or you could use a strap wrench, or you could use 64.5(?) mm socket, or...
2013 TE w/ KDSS Nav
Old 03-13-2021, 05:23 PM #8
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold
MeefZah's Avatar
I respect your ingenuity.
That said, you don't have to drop the filter drain bolt. It's an extra step that maybe makes the job like 10% less messy.
I just unscrew the filter housing, leaving the drain bolt in place. Turn the filter housing upside down to let it drain.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 10:29 PM #9
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
I second the impact comment but suggest a butterfly impact.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 04:22 AM #10
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
What @00Sebby said.
And if you have the metal replacement housing it will be even more apparent that you will tighten until it bottoms out and it will not turn any more. The plastic ones will accept a little torque after being fully seated but not the metal ones.
I can almost remove my metal one by hand.
To make sure it stays in place when undoing the oil filter drain I hold the housing in place with big channel lock pliers.
Sometimes I do the @MeefZah method, it’s just a little more messy. But I bet that’s how the dealer oil changers do it, it’s faster.
Old 03-14-2021, 05:10 AM #11
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough Axix23 will become famous soon enough
Axix23's Avatar
Mine was stuck too. When I turned to get the nut loose, it loosen the the entire filter. Lol
Axix23 is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 05:56 AM #12
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Originally Posted by ElectroBoy View Post
...........Sometimes I do the @MeefZah method, it’s just a little more messy. But I bet that’s how the dealer oil changers do it, it’s faster.
Yep, that's how my Tech at the dealership does it. They don't mess around with the center plug.
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Saker’s Ebony Build | Saker’s Previous 2014 Midnight Build | Scuba Mod| Scuba Mod w/ Locker | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 03-14-2021, 08:45 AM #13
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
Thats a great idea for a tool. Nice work.
I just put a wrench on the filter drain nut and hit it sharply with my hand and it broke free. If I tried to turn it the whole thing moved. This was from the factory on the first oil change.
First Oil Change on My 2020 SR5 Premium Before a Trip for Fluid Film
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 02:26 PM #14
3kushn's Avatar
3kushn 3kushn is offline
3kushn is on a distinguished road
3kushn's Avatar
Easylife45 I second the impact comment but suggest a butterfly impact.
Why Butterfly?
3kushn is offline   Reply With QuoteReply With Quote
Old 03-15-2021, 11:25 AM #15
this is the 5th gen section captnsolo, they dont use canister type spin on filters like a 4th gen.... & the spin on filters are usually 3/4-1 full turn, not 1/4 turn.
change , filter , housing , oil , plug
ATF drain plug stuck? freeflight 4th Gen T4Rs 2 07-16-2016 05:53 PM
Stuck Diff Drain Plug planeboy95 4th Gen T4Rs 12 10-11-2015 10:11 PM
Quick oil change question - locate drain plug nysimonsez Maintenance/Detailing 15 03-31-2008 12:41 PM
1st oil change... filter and plug torque settings? FlipIam Maintenance/Detailing 5 12-04-2006 08:44 PM
Plug at '06 Oil Filter Drain Bob Kazian Maintenance/Detailing 1 02-15-2006 09:28 AM
