Old 06-22-2022, 10:45 PM #1
Predatorsniper2005 Predatorsniper2005 is offline
Predatorsniper2005 is on a distinguished road
Connect Fog Lights to my Switch Panel?
The factory fog light switch only works when the headlights are turned on. They don't come on during switch accessory or when the high beams are engaged. So I can assume that I can unplug the factory harnesses and run power to them from my auxiliary switch panel? Does this sound correct? If so, where do I get the factory wire harnesses to plug into the factory fog lights?
Thank you all in advance!
-Mike
Last edited by Predatorsniper2005; 06-22-2022 at 10:45 PM. Reason: Correct the title
Predatorsniper2005 is offline   Reply With QuoteReply With Quote
Old 06-23-2022, 12:16 AM #2
Ascole Ascole is offline
Ascole will become famous soon enough
I have my fog lights hooked up to my switch panel, fairly straight forward but I did end up cutting the stock wires. I can post pics when I have my car back
Ascole is offline   Reply With QuoteReply With Quote
Old 06-23-2022, 12:19 AM #3
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
There’s a 4th gen mod where the fogs work independently of the headlights. I don’t know if there’s a similar mod for the 5th gen.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 06-23-2022, 01:29 AM #4
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
Or you can get this;
The Brite Box for Toyota 4Runner | Aspire
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 06-23-2022, 01:47 PM #5
Billyrides Billyrides is offline
Billyrides is on a distinguished road
The Brite Box is what I have on mine. I do a lot of backroads, early morning driving heading to fishing spots. The brights combined with Diode Dynamics SS3 fogs make a massive difference in spotting deer on my way to the lakes. Very easy to install. I just did the fogster option if I remember. If I want the fogs off, I turn them off like I normally would on the factory stalk.
Billyrides is offline   Reply With QuoteReply With Quote
Old 06-23-2022, 02:29 PM #6
What kind of plugs do I need that will go into the back of the factory fog lights?
Old 06-23-2022, 02:36 PM #7
I left the stock plugs in, cut the power wire and re ran a new wire to the panel unit under the hood.
Old 06-23-2022, 05:45 PM #8
Ascole,
Hello, I'd rather just unplug the factory harnesses and purchase new ones for my switch panel. If I ever sell the vehicle, then I can revert my ride back to the factory switch.
Thanks
Old 06-23-2022, 06:55 PM #9
Bombguy Bombguy is offline
Bombguy is on a distinguished road
-Mike
Just an FYI, in most of the US it is illegal to run your high beams with your fog lights on while on public roadways. Not an issue if off-roading, but something to keep in mind.
Bombguy is offline   Reply With QuoteReply With Quote
Old 06-23-2022, 08:04 PM #10
Bombguy,
Thank you for the heads up, didn't know that. I think that is strange, because if oncoming traffic comes over the hill, I'm going to go back to my low beams, interesting! I plan to eventually go to the DD Pro's or Max's for my Fogs, but for now, I'd like to get it wired independently.
Be Blessed!
Old 06-25-2022, 09:00 PM #11
Fog Light Plug Type?
What plug type goes onto the back of the factory 2022 LED fog lights? I assume I can just buy 2 of those harnesses?
Old 06-26-2022, 10:34 AM #12
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
Also if your state requires annual vehicle inspection, check lighting requirements. Most states do not allow more than 4 road legal lights to be on at same time. This why fogs turn off with high beams as when high beams are activated high and low beams, total of 4 lights, are illuminated on the 4runner. If they find you can turn on the fogs with high beams illuminated they can fail you.
And disabling the fogs just for inspection probably won’t fly either as typically all installed lights have to functional to pass inspection.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 06-27-2022, 05:55 AM #13
Saker's Avatar
Saker Saker is online now
Saker's Avatar
There should be a number on the harness end plugs. Use an interwebz search, someone will have them that you can purchase.
Best Regards,
Saker
Saker is online now   Reply With QuoteReply With Quote
Old 06-27-2022, 08:06 AM #14
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
2015 5th Gen Independent Fog Light
Turn on Fglights on their own, without low beams
Fog lights with high beams... the easy way
ANTMAN'S Thread
Antman's Foglight mod is awesome!
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 06-27-2022, 12:40 PM #15
OP,
Thanks for the reply, not looking to do a mod, I'm looking to run my fogs off of my switch panel. I just need to know the plug type going into the back of my factory fog lights. I can buy harnesses from there...
factory , fog , harnesses , switch , wire
Wire Switch to all Interior Lights for On/Off Ability? derekl123 4th Gen T4Rs 19 05-25-2021 07:02 PM
How Can i Wire the dash dim switch to AUX lights? infamousRNR 3rd gen T4Rs 31 01-03-2020 01:20 AM
How to wire rock lights to come on at unlock and with a switch? Zmartin19 5th gen T4Rs 29 02-11-2019 07:25 PM
Possible to wire Factory reverse lights to switch? rayofsi 5th gen T4Rs 2 11-24-2018 05:33 PM
ID1 Radio Installation Sub Assy Wire and Instrument Panel Wire (Left Kick Panel) caj4au Engines / Suspension / Wheels / Tires / Audio / Accessories 0 12-13-2011 10:27 AM
