Old 03-14-2026, 09:19 PM #31
RBLACAUSA's Avatar
RBLACAUSA RBLACAUSA is offline
RBLACAUSA is on a distinguished road
RBLACAUSA's Avatar
Originally Posted by ArthurKotb View Post
The entire metal body of your car is negative/ground. There is a wire that comes from the relay to the horn. It should be near the horn. (see photo) That wire is positive. You didn't have to remove the horn to test it, but it appears to me that your video shows it hooked up backwards; positive to the horn body and negative to the input voltage. I'm not sure that it makes a difference. The sound coming out was not normal. It should have been quite loud. Positive wire from the battery connects to the input tab on the horn (not the body). Hold the negative wire firmly to the metal part of the horn, but don't touch the positive and negative together; lots of sparks. You probably didn't make a good connection.
When you press the horn button you are closing contacts in the steering column that engage a relay. When the relay engages it closes a circuit that provides power to the horns. The relay could still click and have bad contacts, preventing power from going to the horns (but not likely). If you are measuring 12 volts at the wire that connects to the horn, when someone presses the horn button, then the relay is good and the horn is getting power. Some cars have a jumper wire from one horn to the other. Some have 2 separate wires. (The reason for the relay is because of wire thickness. The wire from the contact in the steering column is small, because all it has to do is close a circuit to the relay. The relay engages and closes the circuit on much thicker wires because the horns draw more amperage.)
If you have done the test on both horns and one doesn't work and the other one just makes that funny noise in your video, then I would say the horns are bad. You won't get shocked, you're working with only 12 volts DC, much too low to shock you. Get a good solid connection to the horn's body (negative) and the input contact (positive). The horn should be really loud if you have a good contact.
In my attached image you see the 2 horns on my 04 T4R. You can see the wire on the right one. The wire for the left horn is hidden by the horn. Something I've not noticed before is a set of wires on the left going to a small holder. This is probably a fuse to protect the wires from overloading. I'm not sure because I've not seen this on other cars.
You don't need to remove the horns to test them but it's looking like they're both bad. There is one more test you could do if so inclined and if you have a multimeter. Plug the wire to the horn to the red/positive lead of the multimeter. Clip the negative lead to the body or negative post on the battery. Set the multimeter to DC volts in the 20 volt range. Blow the horn. Meter should show 12 volts DC.
If you are satisfied with your tests, buy 2 new replacements; hi and low. (I'm a pack rat and I would keep the old horn that still works. Something to test with or give to someone else.)
Currently experiencing Horn Hell with my '04 4Runner and my searching brought me to this thread among others on T4R. I'm not certain but I am pretty sure that the gizmo that you think is a fuse, is actually a sensor of some type, likely outside air temperature sensor.
'04 4Runner 4X4 SE V8
'06 4Runner 4X2 SE V8
'06 LX470
RBLACAUSA is offline   Reply With QuoteReply With Quote
Old 03-14-2026, 10:02 PM #32
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker has a reputation beyond repute AuSeeker has a reputation beyond repute AuSeeker has a reputation beyond repute AuSeeker has a reputation beyond repute AuSeeker has a reputation beyond repute AuSeeker has a reputation beyond repute AuSeeker has a reputation beyond repute AuSeeker has a reputation beyond repute AuSeeker has a reputation beyond repute AuSeeker has a reputation beyond repute AuSeeker has a reputation beyond repute
Real Name: Skip
Originally Posted by RBLACAUSA View Post
Currently experiencing Horn Hell with my '04 4Runner and my searching brought me to this thread among others on T4R. I'm not certain but I am pretty sure that the gizmo that you thing is a fuse, is actually a sensor of some type, likely outside air temperature sensor.
Without going out to my 4runner and looking, if that "gizmo" is the one on the center grill support, then yes it is indeed the "outside air temperature sensor" I have had to replace mine and that's where it is.
2004 Limited V8
Old 03-16-2026, 09:32 AM #33
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough ArthurKotb is a jewel in the rough
ArthurKotb's Avatar
Real Name: Rich
Yeah, 3 years ago I didn't know what that was. Now I do; it's the outside temperature sensor.
Rich
2004 V8 4Runner 163K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 09-13-2026, 10:15 AM #34
henley henley is offline
henley is on a distinguished road
I’d consider the horn fuse/relay and the steering-wheel horn switch or clock spring, since the panic button still activates the horn.
henley is offline   Reply With QuoteReply With Quote
horn , normal , press , sound , watch/listen
Car horn not working kiyeoul 5th gen T4Rs 51 08-08-2023 12:57 PM
Horn Stopped working...Help Please '01T4R 3rd gen T4Rs 28 02-01-2018 06:45 PM
Horn not working crosso 4th Gen T4Rs 1 09-28-2011 08:37 PM
horn not working robert8629 3rd gen T4Rs 2 03-13-2010 11:54 PM
Horn not working.... el_jefe 3rd gen T4Rs 2 10-17-2008 09:04 AM
