Old 08-25-2022, 04:53 PM #1
Sgb020 Sgb020 is offline
Sgb020 is on a distinguished road
Changed rear diff fluid today
Today I hit 29k thousand miles on my 4Runner. I decided to change my rear diff fluid at 29k miles. My 21 Tacoma rear diff went out at 8k so I decided to change my 4Runner as a precaution. My question is should I wait until 50k to change the transfer case and front diff since I hardly put it in 4 wheel drive? I used 75w90 gl5.
Sgb020 is offline   Reply With QuoteReply With Quote
Old 08-25-2022, 04:53 PM #2
Old 08-25-2022, 05:36 PM #3
Whippersnapper02's Avatar
I'm doing everything at 50K including the transmission.
Old 08-25-2022, 05:47 PM #4
FoxtrotRomeo FoxtrotRomeo is offline
FoxtrotRomeo is on a distinguished road
I don't have a 4R yet - but owned a 2013 FJ Cruiser from new until 2021. The FJ's owners manual said to run 4WD for a few (10?) miles every month. I did this maybe 8 months of the year. I did not offroad much.
Does the 4R require the same?
FoxtrotRomeo is offline   Reply With QuoteReply With Quote
Old 08-25-2022, 05:49 PM #5
Yes I believe all Toyota 4wds recommend this but it's just good practice to exercise your 4wd. Just find a straight road.
Old 08-25-2022, 06:27 PM #6
Saker's Avatar
Saker Saker is offline
Saker's Avatar
My FJ manual stated the same as both of my T4R's............... once a month for 10 miles.
Best Regards,
Saker
Old 08-26-2022, 03:56 AM #7
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Interesting your rear diff went out at 8k on your taco; I changed my rear diff fluid on my 2019 4R at 3k and it was under filled from factory. Lots of metal shavings and the fluid was shot. I would defiantly change the T-case and front diff.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 08-26-2022, 05:22 AM #8
Matt831 Matt831 is offline
Matt831 will become famous soon enough
I did both diffs and t-case at 25k on a 2019.
Truck saw consistent 4WD usage in that interval.
Rear diff fluid was similar to OP in color, no metal shavings.
Front diff and t-case were honey gold still.
I did not send the rear oil out for analysis but judging by the color alone, it needed to be changed. I would not say my truck sees severe usage but there are months at a time I am in 4WD or on dirt. Another note, I have no breather extension on the rear, had a few deeper crossings but noticed no water contamination when draining.
Matt831 is offline   Reply With QuoteReply With Quote
Old 08-26-2022, 07:27 AM #9
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Yes. I go 50K on both differentials and transfer case using Mobil Delvac Synthetic 75w90. 306K miles on the truck.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 08-26-2022, 08:11 AM #10
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
This is a good reason for all new owners, whether brand new, or new to you, to check all fluid levels soon after purchase.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 08-26-2022, 09:26 AM #11
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
Good info. Just hit 35K on my 2018 and this is on my to do list. Been getting reminders from the dealership to do all 3 and an injector service for a total of $500..I think I'll be doing it myself..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 08-26-2022, 09:53 AM #12
dedonderosa dedonderosa is offline
dedonderosa will become famous soon enough
on my 17 TRDP, i did both front and rear diffs at 15k miles, now just about at 45k miles and will both diffs, transfer case and trans now.
brake fluid i also do every 2 years regardless of miles
but one other fluid people always for get about is doing the power steering fluid which gets very dirty and is overlooked. Valvoline MAXLIFE atf is a good choice for PS fluid
dedonderosa is offline   Reply With QuoteReply With Quote
Old 08-31-2022, 01:44 PM #13
Planetcat Planetcat is offline
Planetcat is on a distinguished road
Nice.
I'm a big fan of changing the diff and trans fluids more often than recommended. I like Amsoil in the diffs, but have used Valvoline in my SxS and it's made that rattling drivetrain nice and quiet.
2022 4Runner TRD Off Road Premium, Front Bilstein 5100’s/Rear Rancho RS9000x, RCI Skid Plate, Goodyear Duratracs.
Planetcat is offline   Reply With QuoteReply With Quote
Old 04-06-2024, 12:46 PM #14
Teocalli Teocalli is offline
Teocalli is on a distinguished road
Yeah my rear diff bolt was loose !
Teocalli is offline   Reply With QuoteReply With Quote
Old 04-06-2024, 06:32 PM #15
Tooly Tooly is offline
Tooly is on a distinguished road
I did my front & rear diffs along with the transfer case last weekend at 50,000km. The transfer case fluid was still golden looking. The front and rear diff looked similar to what is pictured above by Sgb020. I used Redline 75W85 for the diffs and Redline MT-LV for the transfer case.
2021 4Runner ORP - Canada Spec
1989 Land Cruiser BJ74 - Sold
1986 Land Cruiser BJ70 - Rusted Away
Tooly is offline   Reply With QuoteReply With Quote
change , diff , fluid , rear , today
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
Changed rear diff fluid and greased drive line, now trans runs hot Skunkworks 3rd gen T4Rs 11 06-20-2019 04:20 PM
Changed Diff Fluid, Have Vibration - Thoughts? anotherrunner83 4th Gen T4Rs 9 09-06-2012 10:03 PM
Changed my Transmission Fluid today.... jstutz101 4th Gen T4Rs 7 03-30-2010 03:04 PM
Changed the breaks today and the fluid NewYorkRifleMan Maintenance/Detailing 9 02-17-2007 11:53 AM
