I am trying to replace the map light bulbs but they will not come out. Does anyone have a method to try to get them out? I have tried the tape pulling method already and I cannot make it work Thanks.
You can try using a piece of tygon tubing slipped over the bulb. Works for me every time!
....Hey!....try this video...it was very helpful when I swapped All my lights out...and these folks are excellent and funny at the same time!....Good Luck!
It is okay. I had to remove the entire map/light upper console. It was easy. I am at fault for this too but you should get into a habit of previewing the message before you post. Thanks.
