Old 03-06-2023, 04:41 PM #1
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
TRD Skid Plate Changes over GEN5?
Has the TRD Skid Plate changed over the years for GEN 5? Specifically, would this skid plate fit a 2023:
Amazon.com
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 03-06-2023, 05:10 PM #2
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Amazon.com
That's a lot of money for a weak skid plate. My 3/16 is severely bent in one spot (I mean the entire pax side front half) and its internal mid-plate supports are both bent, and I have replaced the rear bolts a bunch of times and had to rehread one of the holes.
If you are seriously offroading, by which I mean carrying any speed over rocky terrain or sliding, dropping on skids and sliders, you will want steel. If you are not, I think you can do just fine on the stock one. My Moab friend is still using stock on his GX 470 though he is slow. My 2c.
Old 03-06-2023, 05:42 PM #3
Humble Leader's Avatar
Amazon.com
Toyota parts site says that fits 2023s. might want to also get hardware kit
Hardware Kit Front Skid Plate - Toyota (PT938-00140-AA)
Old 03-06-2023, 06:22 PM #4
This is going on my wife’s 20233 Off-road that’s been ordered, but not allocated. 95+% highway driving and she’s not hard charging rock gardens.
Old 03-06-2023, 06:37 PM #5
Thanks for the hardware suggestion, but the Saker stud-mounting is the only way to go on these.
Old 03-06-2023, 11:10 PM #6
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Lots of people complain about the OEM TRD skid plate, but it has one big advantage over any other skid plate I have seen: the front rises almost to the the bottom of the front bumper. Everybody else mounts to the cross beam which is well below the front bumper.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-08-2023, 08:47 AM #7
FoxtrotRomeo FoxtrotRomeo is offline
FoxtrotRomeo is on a distinguished road
I put one on my 2023 ORP a few months ago. Fit fine. Used the provided hardware (2 bolts). Needed to reuse 2 bolts iirc.
What is the "Saker stud mounting" you are referring to?
Thanks
FoxtrotRomeo is offline   Reply With QuoteReply With Quote
Old 03-08-2023, 10:15 AM #8
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
Thanks
Something you do with your wife/ GF (or both at the same time) in the confines of your bedroom, or tent, or the side of a remote hiking trail or by a cool mountain stream...sorry got carried away.
jk...its where you replace the bolts with studs as some ham fisted mechs tend to strip the threads in the frame or lose the spacers that go in the front bolts or place them in the back position. anyways, makes removal more idiot proof.
link anyone
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 03-08-2023, 12:44 PM #9
Thanks
https://www.toyota-4runner.org/5th-g...ted+with+Studs
Old 03-08-2023, 10:29 PM #10
link anyone
You know I’m working down at my home in SoCal, while my wife is busy playing retirement at our ranch in Montana. It’s hard to ignore a
stud mount threesome in a tent at the moment. I am thankful for the distractive review I am working on.
Old 03-08-2023, 11:33 PM #11
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Amazon.com
I am not aware of any changes to the mounting of the skid plates....
mine fit perfectly on my 21 TRDORP.
May also want to chase thread holes prior to stud mounting. Chasing the threads and the stud mounting projects are both easily done and will possibly save you some heartache as well.
For the one that states the plate is weak, I have a much different opinion.
My 14 T4R had one on it. One morning at approximately 3 AM on the way to work after a hurricane passed thru our area. I encountered a 20" Dia utility pole across the roadway. Had been raining, road was dark, lights out because pole had pulled the wires down with it, pole was dark & blended in with the roadway and I encountered it at enough speed to send me over to top of the pole and landed my T4R on the other side about 10 or more feet...(didnt measure)
Impact deployed all air bags but the passenger side front.
If it were not for the TRD skid plate, IMHO, the impact would have pushed both front tires into the cab area. Why didn't it, because the TRD Skid Plate started raising the front end up before the tires impacted the Utility pole and started my T4R in an upward motion to go over the pole.
Possibility that I could have had broken leg or legs if I didn't have a TRD Skid plate on my 14".
I was able to push the door open and walk out!
YMMV
Best Regards,
Saker
fit , plate , skid , specifically , trd
5th Gen Genuine Toyota OEM front skid plate (not a PRO skid plate) - $50 (North Seatt SI2IS2T4R For Sale: T4R Items 0 05-27-2021 12:14 AM
*UPDATE* I have purchased a skid..98 4Runner front skid plate WTB TraumaHawk Free 4 11-11-2020 11:46 PM
New Gen5 Hardware: Skid plate bolts, shock mounts, who's got em? rmbertoldi 5th gen T4Rs 0 12-11-2018 03:52 PM
SoCal - Aftermarket 4th Gen 4Runner Skid Plate + Filler Plate - $250 boxtree619 For Sale: T4R Items 2 02-04-2017 10:00 PM
