Old 11-22-2023, 01:25 PM #1
lawless97 lawless97 is offline
lawless97 is on a distinguished road
How do I know when nmy drive belt needs replacing?
At my 65k maintenance for my 2016 SR5, they recommended drive belt as routine maintenance, since the schedule calls for 60k or 5 years. I've heard some people say they've gone 100k on theirs. How do I know it needs to actually be replaced? It looks okay to me and I don't see any signs of wear, but could there be stress on it that isn't visible that causes it to eventually break?
How do I know when nmy drive belt needs replacing?-pxl_20231122_171854879-jpg
lawless97 is offline   Reply With QuoteReply With Quote
Old 11-22-2023, 01:29 PM #2
ASUMTNEER ASUMTNEER is offline
ASUMTNEER has a spectacular aura about ASUMTNEER has a spectacular aura about
If it's not making noise or doesn't show any cracks on the inside of the belt, I'd keep rolling with it. It should easily go to 100k, then you might think about replacing it as a preventative measure.
ASUMTNEER is offline   Reply With QuoteReply With Quote
Old 11-22-2023, 01:55 PM #3
Great news! I can save $260 for now. Thanks!
Old 11-22-2023, 03:34 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
You can save about $200 of that by changing it yourself when needed.
Old 11-22-2023, 05:15 PM #5
Whippersnapper02's Avatar
There's a tool to measure the rib depth. The new belts tend to not crack so it's hard to read them.
Old 11-22-2023, 05:16 PM #6
wsgoat's Avatar
wsgoat wsgoat is offline
wsgoat has a spectacular aura about wsgoat has a spectacular aura about
wsgoat's Avatar
This!
The serpentine belt is cheap and easy to replace, and so are the belt idlers. You'll save a boat-load of money if you learn to do some of this basic maintenance yourself.
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
wsgoat is offline   Reply With QuoteReply With Quote
Old 11-22-2023, 08:45 PM #7
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
I checked my '19 owner's manual and unless I missed it, it doesn't list a mileage or time to change the drive belt. It says the initial inspection happens at 60k miles then every 15k miles afterwards.
That said, I have always changed mine at 90k miles as a preventative.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 11-23-2023, 01:28 AM #8
choochoo choochoo is offline
choochoo will become famous soon enough choochoo will become famous soon enough
Just changed mine on '17 with about 97K miles. Planned for early preventative maintenance at 100K. Belt change took maybe 20 minutes. Checked idler and tensioner pulleys and they were all spinning fine. Nothing squeaking.
Old belt looked fine - no cracking on ribs. 60K sounds way too early.
choochoo is offline   Reply With QuoteReply With Quote
Old 11-23-2023, 05:24 PM #9
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
Slip your camera under that top idler pulley where the belt is flexed backwards and take a picture. If you don't see cracks, you ought to be good. They're simple to change. Only cost about 50 bucks. Make sure when you change them that you take the time to exercise the pulley tensioner otherwise you may have problems. Sometimes they stick after not moving for some time.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 04-28-2024, 12:22 AM #10
coltm4's Avatar
coltm4 coltm4 is offline
coltm4 is on a distinguished road
coltm4's Avatar
I'm at 185k and still on my original belt. I'm thinking of replacing it soonish, but tensioners and idlers are $$$
2016 QUICKSAND TRD PRO,Rear diff breather mod, Salex organizers, Huskyliners, CBI sliders, RCI TRD intermediate skid plate, RCI aluminum transmission skid plate, RCI STEEL transfer case skid, RCI Aluminum fuel skid and A arm skid. RagoFab modular storage panel. King extended travel front and rear with compression adjusters. 2" Toytec superflex rear springs.
coltm4 is offline   Reply With QuoteReply With Quote
Old 04-28-2024, 09:07 AM #11
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
2016 with 70k here. Just did mine. It's rubber that's almost 10 years old and is one thing I'd hate to have fail on me on a trip. I was getting a soft squeak squeak squeak on startup when it had rained overnight. I carry the old one as a backup and a spare 14mm (I think, or whatever it is) in case I ever have to change it on the road.
Sent from my SM-S901U using Tapatalk
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 05-01-2024, 09:49 AM #12
desertred desertred is offline
desertred is on a distinguished road
155K on my 2010 and the original belt (14 years old). Having the dealer to do a radiator flush today but then started to think about the serpentine belt and water pump. How many of you have had to replace the water pump? No drips or leaks from mine but 155K is a long time for a water pump (maybe old school train of thought).
2010 Black SR5 w/Sand Beige leather & all the goodies!
2001 Black & Tan SR5 - gone but not forgotten.
desertred is offline   Reply With QuoteReply With Quote
Old 05-02-2024, 07:07 AM #13
People generally don't do the water pump on these as PM. They last a long time. Personally I'd do the belt and leave the WP alone until it starts giving problems.
Hoses maybe? I'd do them before the WP.
Old 05-02-2024, 11:47 AM #14
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
The accessory belt seldom breaks or has "wear". The usually problem is the belt will become glazed due to heat, then it will squeal as it slips over the pulleys. That is the time to replace it.
You can tell a belt is glazed because it will be shiny and the ribs will be hard and possibly cracked. Yours does not look like that.
Some people try to extend the life of a glazed belt by , using "belt dressing", available at any auto parts stores, but that is only a temporary measure if the belt is already glazed.
fkheath is offline   Reply With QuoteReply With Quote
Old 05-03-2024, 10:35 PM #15
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Replaced mine at 8 years/94k miles. $12 for the Bando on Amazon at the time. I’ve got 45k on the replacement and another $12 Bando ready to go in the parts box. Got spare idlers too just in case.
1000MPH is offline   Reply With QuoteReply With Quote
belt , drive , maintenance , replaced , signs
Can I drive without AC belt? Aelfwine 3rd gen T4Rs 20 09-26-2020 10:48 PM
Replacing drive belts... AC belt is being a pain! DK327 3rd gen T4Rs 19 03-06-2017 05:23 PM
Drive Belt DIY superdjl 4th Gen T4Rs 1 01-08-2011 09:46 PM
How much for a new drive belt? dannyg 4th Gen T4Rs 9 09-29-2010 07:06 PM
Replacing Drive Belt on 2004 4Runner V6 raylee011 4th Gen T4Rs 6 10-01-2009 11:01 AM
