Originally Posted by arthurm
I've had the truck for seven of its ten year life and never even been in water that deep. The drain holes were clogged and I never checked.
As this is UHS (ultra high strength) steel, shops are telling me that they will only replace it as officially required by Toyota. That's $7K per side or more, one quote.
Welding UHS seems to be a specialized and technical job. Finding a qualified person will be difficult.
The more I think of the welding difficulty, the more I lean towards the 3M structural adhesive and mild steel. I'd bet that's more than enough to keep me going.
Frankly, I can't believe that simply clogging these drain holes leads to total replacement of these parts at considerable cost. I'm sure a repair will return the strength to good enough, albeit not up to Toyota's standards.
the drain holes were clogged with mud or dirt? what was clogging them? that looks like some serious salt water damage after prolonged exposure. at $7K per side no way I'd put that money into a 2013 truck. If I had the $14K to spend I'd sell the 4runner as is and use the proceeds plus $14K to move onto another vehicle. I bet if you start poking around there with a screw driver you will poke holes all through that rocker. is there any good steel left?
