Old 01-29-2024, 06:12 PM #1
Charles Bronson Charles Bronson is offline
Charles Bronson has a spectacular aura about Charles Bronson has a spectacular aura about
Want to run OEM LED low/halogen high beam housings in a 2020 ORP
I want to run the OEM LED low/halogen high beam housings in my wife's 2020 ORP. I read a ton of the threads on this forum and some of it is confusing. I have no desire to get the OEM LED low/high beam setup as we rarely run the high beams and honestly find the halogen lighting on the high beams to be plenty strong.
I just want to make sure I understand things correctly before ordering parts. Based on my research, I need to order and complete the following to do the conversion:
LED w/ Halogen High beam
Left: part# 81070-35600
Right: part# 81140-35610
I can then unpin the low beam connectors from the old housings and install install onto the new housing and that's it to complete the conversion.
If I don't want to unpin the wires and swap connecters, I can buy the "No shutter" harness here: 4Runner 2014 - 2020 OEM bi-LED Headlight Conversion Harness | FBC Harness Solutions
Thanks for the help.
Charles Bronson is offline   Reply With QuoteReply With Quote
Old 01-29-2024, 06:36 PM #2
Saker's Avatar
Saker Saker is offline
Saker's Avatar
I just looked up everything, from the original post and it looks like you are good to go with your parts!
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Saker’s Ebony Build | Saker’s Previous 2014 Midnight Build | Scuba Mod| Scuba Mod w/ Locker | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 01-30-2024, 06:14 PM #3
Thank you!
Old 01-29-2024, 10:54 PM #4
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
I don't know if the part numbers are correct but I did this exact install on my '19 TRD ORP. I got a set of used headlights from a '21 T4R off of ebay. I did the unpin deal as there was no harness available at that time. No problems at all and they work & look great.
In case you aren't already I'd suggest swapping out the fog lights with an OEM LED set to match. They are a direct swap as the connector is the same and will be easy to install since you'll already have the bumper off to install the headlights.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 01-30-2024, 12:04 PM #5
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Second that. There is a guy on Ebay selling those. His price is now down to $35 each: https://www.ebay.com/itm/234936589516
fkheath is offline   Reply With QuoteReply With Quote
Old 01-30-2024, 06:15 PM #6
Thanks. And yep, we installed the Pro LED fog lights when we did the Pro grill, front and rear scuff plates, etc.
beam , high , led , oem , run
First Time Using Automatic High Beam Dim Function on my 2020 SR5P RichinRidgewood 5th gen T4Rs 12 01-27-2024 10:07 AM
Led low beam with halogen high? K9trainer 5th gen T4Rs 17 11-24-2021 10:15 AM
2005: Current HIR options for low beam (9006) & high beam (9005)? Iron Chef 4th Gen T4Rs 6 03-15-2021 09:07 AM
HID (Low-Beam Xenon/ High-Beam Halogen) -H4 5000k 55w on Projectors Cuco 3rd gen T4Rs 7 08-07-2016 11:17 PM
Anything special about Quad Beam Halogen Headlights? Thai General Discussions 3 09-03-2009 03:55 AM
