Old 07-22-2019, 09:25 PM #1
Gecko's Avatar
Gecko Gecko is offline
Gecko is a jewel in the rough Gecko is a jewel in the rough Gecko is a jewel in the rough
Gecko's Avatar
Front End Popping Noise When Turning Left?
Hi all,
I know describing and diagnosing sounds is everyone’s favorite thing, but curious if anyone here has noticed or fixed a popping noise that seems to come from the front left and occur when the weight shifts - like making the rounds to exit a parking garage or making a sudden left onto uneven pavement, etc ?
I’ve noticed my truck doing it lately and it’s a popping noise that sounds a bit like a contact of some sort. It’s at the dealer now and I can’t tell if I’m being overly picky or if something might really be wrong. Of course, drove with two of their master techs and the sound was nowhere to be heard. It's more noticeable when the 4R has been sitting for a while and I first start moving, so they let it sit over the weekend and were going to try driving today but I haven't heard anything yet.
Strangely, there is no noise coming from the right side at all, even under the same circumstances.
Thanks in advance.
2021 Lexus GX 460 Luxury , Atomic Silver/Black @LandCruiserDNA
Previous: 1999, 2016 and 2019 4Runners
Gecko is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 10:47 PM #2
Jbatman's Avatar
Jbatman Jbatman is offline
Jbatman will become famous soon enough Jbatman will become famous soon enough
Jbatman's Avatar
Man it’s like I wrote this post... I had/have the exact same symptoms, only on my right side. Coming down parking garages would provide a single knock/pop sound and driving on road with left-to-right dips would produce a sound similar to an old rickety suspension or box spring mattress.
I had the dealer look and double check everything they could think of during my last service but they were unable to find anything.
Oddly enough I haven’t heard anything lately. The only thing I can think of that’s changed lately that could affect it would be that I’ve added more weight prepping for a trip?
I’m eager to hear if the dealer finds anything!
2019 TRD ORP Super White | 6112/5160/T13 (+2/1.5") | Wildpeak 285P | XenonDepot LED | Pedal Commander | Gobi Stealth No-Rise Multi-Light | Shrockworks Sliders | RCI Skids | WeBoost Reach
Jbatman is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 11:06 PM #3
Chilow Chilow is offline
Chilow will become famous soon enough
Could be a loose upper control arm long bolt.
Chilow is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 11:11 PM #4
Gecko's Avatar
Gecko's Avatar
Frustrating, right? Same thing you mention though - it's mostly a knock, and sometimes a bit of a squeak. Same exact circumstance as you note. I'll let you know what comes of my dealership visit.
Old 07-23-2019, 12:45 AM #5
Sonoran_Desert Sonoran_Desert is offline
Real Name: Jo
Sonoran_Desert will become famous soon enough
Real Name: Jo
Try Hood Latch
Maybe try lubing hood latch, double check hood bumpers.
Sonoran_Desert is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 07:32 AM #6
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
how many miles? check your jack is secure and spare tire first.
Changing the front sway bar bushings solved my issue. They wear out and aren't to difficult and not expensive to change.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 08:16 AM #7
Gecko's Avatar
Gecko's Avatar
Funny you mention that. I had my 4R in and out of the dealer 6 times for a front end, high pitched squeak and they couldn’t figure it out. One day, I leaned against the front of my car and heard the same squeak - it was indeed the hood bumpers. One was twisted all the way down, so the hood was flexing.
Also, the point about sway bar bushings is a good one. When they were trying to fix the sound above, they replaced them and I didn’t notice this knocking noise until about that time.
Also, just passed 28k miles, so still fairly new.
Thanks, all.
Old 07-23-2019, 08:52 AM #8
Jivewalker's Avatar
Jivewalker's Avatar
I feel like something is not torqued correctly. LCA bolts, sway bar bolts, shocks, propeller shaft,etc. I would go over all of that.
I am fragile.
Not like a flower.
But like a bomb.
Old 07-23-2019, 09:42 AM #9
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Maybe the upper control arm c clip. It was documented as a prior repair on my 4runner.
Chasing an Elusive Noise - Toyota 4Runner Forum - Largest 4Runner Forum
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 09:52 AM #10
karmatp karmatp is offline
karmatp is on a distinguished road
So crazy, I have been going out of my mind with mine. It only happens when turning left and mine is more of a bloop bloop sound. I have tightened stuff, lubed stuff, I don’t know what else to do. I took of my center caps, it honestly sounded like the plastic from it was loose and popping while turning. Turns out, my runner looks way better without center caps so that is one good thing that came out of it.
Mine sounds like plastic, it is crazy. I have honestly considered getting rid of the darn thing because I am going out of my mind trying to find a solution.
karmatp is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 10:13 AM #11
motoguy13 motoguy13 is offline
motoguy13 is on a distinguished road
i think i have the same noise you have on my 16 sr5, it is super frustrating i does it when im not trying to make it or listening for it, always seem to notice it when i have the family in the car making a ton of noise so i cant pin point it, i notice it more when shifting weight from side to side on dips in a parking lot.
as a dealership tech myself its even more frustrating that i cant figure it out, although i have noticed it less since i replace my rear control arms for a creaking from the bushing, found that by grabbing the roof rack and rocking the vehicle side to side.
motoguy13 is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 10:24 AM #12
dot_tom's Avatar
dot_tom dot_tom is offline
Real Name: Tom
dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all dot_tom is a name known to all
dot_tom's Avatar
Real Name: Tom
Thanks, all.
I have had a squeak for over 30k miles and cannot find out what it is! This might help! haha fingers crossed.
2017 4Runner TRD OR - Progress Thread
295/70/17 BFG KM3, SCS F5 17x9 -38, Front 5100 Rear MT Icon, Dobinson 314 & 701V, Gobi Stealth, RSG Sliders, ECGS 4.56's, Demello Front bumper, Coastal Off Road Rear Bumper
IG: dot_tom
dot_tom is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 10:26 AM #13
666HailSanta 666HailSanta is offline
666HailSanta is on a distinguished road
Had the same problems described - it's was as simple as torquing the lower control arm bolts to 120ft/lbs. Had 3-4 mechanics miss it before I found this one weird trick dealerships don't want you to know.
666HailSanta is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 10:33 AM #14
Gecko's Avatar
Gecko's Avatar
Forwarded this over to my dealer. Thanks!
Old 07-23-2019, 10:47 AM #15
I've also heard this is common. The lower control arm bolts.
1999 4runner
it’s , left , making , noise , popping
Strange noise when turning left. NewguyNY 5th gen T4Rs 9 11-29-2019 08:52 AM
Popping noise when turning Mantree Classic T4Rs 11 03-11-2015 06:53 PM
Noise/vibration when turning left? kyle_uran 4th Gen T4Rs 11 11-21-2014 07:59 AM
Skipping & knock noise from front when turning left hawkcharmer 3rd gen T4Rs 4 02-25-2013 10:12 PM
Popping noise in front left? Laubage 5th gen T4Rs 18 12-24-2012 06:40 PM
