Old 03-05-2024, 03:34 PM #1
paczowski123 paczowski123 is offline
paczowski123 is on a distinguished road
5th Gen Front Diff Mounting Bolts
Alright so I have searched high and low for the bolt thread, length for the front diff mounting bolts. i have a diff drop installed that I am considering removing due to some noise I am getting and seems some folks experience these noises with diff drops, however, I do not have the factory bolts anymore.
Does anyone know either the part number for these from Toyota or at least the thread pitch/length for them? Online Toyota parts websites seem useless.
paczowski123 is offline   Reply With QuoteReply With Quote
Old 03-05-2024, 04:30 PM #2
DigitalVex DigitalVex is offline
DigitalVex is on a distinguished road
Might be here:
Bolt(For Front Differential Support Assy) | Part #9010514177 | Toyota Auto Parts
DigitalVex is offline   Reply With QuoteReply With Quote
Old 03-05-2024, 09:45 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Just use the dif drop bolts you have, cut an inch off or put the spacers under the bolt head until you get the right ones. You could remove one of the dif drop bolts and take it to Home Depot or, other store, and match up the threads and then buy shorter ones.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 03-05-2024, 09:53 PM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Toyota uses high strength bolts just about everywhere. Home Depot sells weak Chinese junk. Better to go to an industrial fastener store instead of Lowe's or Home Depot.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-06-2024, 10:05 AM #5
Oogs Oogs is offline
Oogs is on a distinguished road
Check Fastenal online.
Oogs is offline   Reply With QuoteReply With Quote
Old 03-06-2024, 10:23 AM #6
Originally Posted by DigitalVex View Post
So I have searched a couple of times and it seems there are many part number for the same exploded picture. While I understand it may be the same bolt shared across different models, I'd hat to order and end up with the incorrect bolts.
Old 03-06-2024, 10:24 AM #7
If i remember correctly the shank on the bolt is longer not the threads, so removing the bolt and cutting down would just remove the top threaded section. If I cannot locate the correct thread pitch/length I may be just removing it and taking it to a hardware store.
Old 03-06-2024, 10:35 AM #8
Real Name: Skip
Real Name: Skip
You can match the bolts/diameter/threads, etc. just make sure you get grade 8 bolts.
2004 Limited V8
bolts , diff , mounting , thread , toyota
Front diiff mounting bolts OC2003 4th Gen T4Rs 3 02-17-2020 07:24 PM
3rd gen LBJ OEM mounting bolts (NIB) jmferg Free 1 02-08-2017 03:00 PM
bolts on front diff what size thursdaymike 3rd gen T4Rs 2 09-15-2014 05:25 PM
need part number for front diff mounting bolt rrands1 Classic T4Rs 2 07-19-2013 05:08 AM
