07-31-2016, 07:14 PM
Rear Shock Bolt size/pitch
Does anyone know the details of the both that goes there? I tried an M12-30, but only got a few threads in.
I'm trying to install my replacement Shin guards, but since the original hardware got lost with the shin guards, I'm not sure what I need to pick up at the hardware store.
Thanks!
Okki
Okki's Build Thread - 2010 Limited: Shrockworks Rock Rails & Full Skids, Gobi Rack, OPT7 LED Roof LIGHT Bar, Rigid E-Series Bumper Light Bar, Hella Horns, Auxiliary Fuse Box, Cobra ST75, TRD Rims, Discoverer ATP LT265/70R17, Rotopax, ARB Twin Compressor, Cargo Area Pressure Gauge and Chuck, Icon billet trailing- and A-arms, Dobinsons Shocks/Coils, Fumuto Oil Valve, Northstar Group 31M, CBI Front & Rear Bumpers !!!
Any time...Anywhere.. My cat can take you.
07-31-2016, 08:34 PM
Real Name: Swartwood
Fine pitch usually
Thanks!
Okki
Not entirely sure but Toyota loves fine pitch bolts generally
That would be an M12 1.25 (or very rarely 1.5) But seriously I'd spend the extra $2 and grab both coarse and fine.
This was the JIS sizing that Exp Portal considers std for a Toyota:
Common JIS sizes on Toyotas (mostly considered metric fine thread):
16mm x 1.50
14mm x 1.50
12mm x 1.25
10mm x 1.25
8mm x 1.25
6mm x 1.00
10 TE - KDSS - Icon Suspension - 285/70/17 Hankook MTs - 4.56 nitro Gears - URD equal length headers
Shrockworks front bumper and sliders - MT Rear bumper- RCI aluminum skids - Dif breather mod - K9 Rack - Warn 10S Winch
Come ride with me: PDX 4X4
07-31-2016, 09:11 PM
Much appreciated
@ Swarty
! I'll shop for a fine pitch tomorrow. M12 is the right thickness. It's just the pitch that's off on what I got. When I tried it in the parking lot, I thought that it got too hard to tighten by hand because of rust. I guess the pitch was the issue.
Thanks
Okki
07-31-2016, 10:49 PM
Much appreciated
@ Swarty
Thanks
Okki
If memory serves me correctly, it is m12 x 1.25. I remember buying the tap.....
I'm 90% sure.
07-31-2016, 11:02 PM
Real Name: Victor
Real Name: Victor
I had bashed one of my lower shock mount bolts and bought the FJToyman lower shock mount skid and decided to buy two new shock mount bolts. This was the PN from Toyota. Took a day to get them in.
2015 Black 4Runner TRD Pro
Mild add-ons - Toytec 2" TRD lift kit w/SAW 1.5" rear spring, Nitto Ridge Grappler 285/70/17 C, 1/4" Aluminum RCI Metalworks Skids - All but the TRD Pro skid. FJToyman lower Rear shock mount skids. C4 Fab sliders. axle & eLocker breathers to ARB under hood, tinted front two windows, BajaRack Stealth with Spylight Sytem, Extreme LED 40" single row light-bar, Blacked out chrome on tailgate. Weathertech in-channel window vent visors and rear cargo mat, Paracord Headrest Grab Handles. H11 LED fogs and XenonDepot headlight kit. Interior LED swap.
08-01-2016, 09:01 PM
Ended up picking up a M12x1.25 30 and that worked like a charm. Went to the hardware store because my local dealer is terrible. Cost was about the same. $2.50 per bolt and 0.50 per washer.
Toyota part number: 90119-A0018 (so you can copy and paste instead of retyping of the image)
Thanks for the details!
Okki
04-17-2024, 02:16 PM
I picked up the bolt from toyota and can confirm M12-1.25 x 25mm with a captive washer that has an OD of about 38mm.
PN:901191-A0018 for $8.80 and took two days to get one into my usual stealership.
Edit: Also Torque to 72 ft*lbs with a 17mm socket
