Old 02-06-2021, 08:14 PM #1
Ih8fizzix Ih8fizzix is offline
Ih8fizzix is on a distinguished road
ABS, braking power low and drive start control malfunction lights
This just happened now. On my 2020 SR5 4x4 with 11k miles.
Display says anti lock system malfunction visit dealer. braking power low,drive start control failure visit dealer.
Will take it in Monday when the dealers open. Has this happened to anyone before? I drove the car this afternoon and moved it from the drievsy to the street. Wife got in to drive it, and called me saying all these warnings are lit up. So random. She’s driving it now and says it’s driving fine, not sure if it’s because it’s brutally cold here so sensors are just acting up. It’s been between 0 and like 10 degrees all day and the car sits out.
ABS, braking power low and drive start control malfunction lights-6f423071-b2a6-44eb-8f5e-665ce51bf4bf-jpeg  ABS, braking power low and drive start control malfunction lights-49aef1bd-f04f-48a5-b596-0e1a43244b3d-jpeg  ABS, braking power low and drive start control malfunction lights-de184280-b09e-409d-a20d-e413b1186bc9-jpeg
Ih8fizzix is offline   Reply With QuoteReply With Quote
Old 02-08-2021, 12:04 AM #2
Tried to switch it from 4wd to 2wd and back to see if it was anything related to that and now it says 4wd malfunction!
ABS, braking power low and drive start control malfunction lights-00c46ca1-bad8-4972-9a81-9cc2accf8c69-jpg
Old 02-09-2021, 02:16 PM #3
Update:
Dealer called and said a 2021 4Runner came in on Saturday with the same issue and that they’ve already done a wheel bearing and master cylinder on it and still not fixed.
He said on mine they’re going to start with a brake booster and that it won’t be here until earliest Friday. He said on the 2021 the brake booster is backordered and won’t be here until the 25th.
In the meantime I’m driving around a 2020 Rav4.
Old 02-24-2021, 02:25 PM #4
Just in case anyone cares, it was a failed master brake cylinder. They replaced it under warranty. They also found a bent brake line. I had to pay out of pocket for that.
Old 02-24-2021, 02:56 PM #5
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Yikes, that's an expensive part. I had to replace one on my 2001 3rd gen 4Runner and the part was over $2k. I haven't seen many failures pop up on 4th and 5th gens which use a similar design boost pump/accumulator setup, but hopefully it's less common than the old 4Runners and Landcruisers which had lots of issues with them as they aged.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 03:16 PM #6
Tbasse01 Tbasse01 is offline
Real Name: Troy
Tbasse01 is on a distinguished road
Real Name: Troy
Looks like they replaced the whole booster instead of the pressure sensor
Guaranteed it was the sensor or bad connection no way a master cylinder is dead after 11k
Reminds me of the master cylinder fiasco at gm dealers in the 80's and 90's pedal going to floor and they say replace master cylinder .... Then again in 6 months pedal going to floor replace master cylinder
*** All they had to do was adjust the automatic brake adjusters in the rear that never adjusted properly**
How many people got ripped off with that
Troy
2016 limited midnight metallic black
68k | LED headlights/fogs | remote start | block heater | LED interior
New to me
Tbasse01 is offline   Reply With QuoteReply With Quote
Old 02-25-2021, 01:14 AM #7
Yeah I initially thought it was probably sensor related especially since it was so cold out. And especially since another T4R was towed in for the same issue. Do you think if it was the master, it failed Bc of the badly bent brake line? I went off roading a few weeks ago and pretty sure I bent it when I came down on a rut pretty hard.
Old 02-25-2021, 10:14 AM #8
Real Name: Troy
Real Name: Troy
Might have effect on pressure and flow with it being bent, but if it was bent almost like a kink I don't think the sensors would like that at all and do all sorts of stupid things
Troy
New to me
Old 01-03-2022, 09:22 PM #9
jim4runnerny jim4runnerny is offline
jim4runnerny is on a distinguished road
Old post, but I just had this exact issue occur on my 2020 4WD 4Runner Limited with 15000 miles. I have an appointment on Monday to have this looked at. Note that it happened to me after the vehicle sat for a day in cold weather (~10-20 degF). I'll let you all know if it ends up being a master cylinder for me as well.
Jim
Jim
'23 4Runner Limited - Blizzard Pearl/Redwood
'20 4Runner Limited - Nautical Blue/Redwood (sold)
'10 4Runner Limited (sold)
'01 4Runner Sport (sold)
jim4runnerny is offline   Reply With QuoteReply With Quote
Old 01-25-2022, 07:58 PM #10
moes4runner moes4runner is offline
moes4runner is on a distinguished road
Jim
just had this happen on my 2021 limited too minutes ago, did you ever figure out what it was? same deal as everyone else, sat out in the cold and then started it and got these messages
moes4runner is offline   Reply With QuoteReply With Quote
Old 02-02-2022, 06:40 PM #11
Charles Bronson Charles Bronson is offline
Charles Bronson has a spectacular aura about Charles Bronson has a spectacular aura about
This is hilarious. I just dropped my wife's 2020 TRD ORP with 20K miles at the dealer for these exact messages. She got the messages after driving around for an hour in ~15 degree weather. The truck sits in a garage all night, but the garage was probably 35 degrees last night. Not exactly super cold.
Charles Bronson is offline   Reply With QuoteReply With Quote
Old 02-03-2022, 02:03 PM #12
jim4runnerny or moes4runner,
Do you have any updates to what Toyota did to fix this issue? The tech thought it was a wheel sensor so he replaced it and the issue is still there.
Old 02-03-2022, 04:26 PM #13
The tech says the electronic ABS/brake controller is bad and has ordered one. I'll update this thread once the repair is done and note if it fixed the issue.
Old 02-05-2022, 11:29 PM #14
Kries40 Kries40 is offline
Kries40 is on a distinguished road
Following ….my 2021 4runner limited with 9000 miles is doing the same thing.
Drive start control malfunction
Pre-collision system malfunction
Braking power low (ABS and Brake light on)
All wheel drive system malfunction
Live in Ohio where its cold and snowy
Kries40 is offline   Reply With QuoteReply With Quote
Old 02-06-2022, 01:05 AM #15
The part the tech ordered won't be here until 2/16. So now the 4runner sits for nearly 2 weeks. I dont know if this is a COVID thing or if this is because so many later model 4runners are experiencing the same issue and the part is in high demand.
There is definitely a fault with the ABS when this happens because when the issue popped up, I went out and did some hard braking and back end would lock up and want to swing around. I couldn't feel any sort of ABS pulsating in the pedal. When I scanned the ECU for codes, nothing showed up.
braking , dealer , driving , it’s , visit
Crawl and hill start malfunction? trdpro2016 Problems & Warranty Issues 0 11-03-2014 06:14 PM
Hill-start Assist Control (HAC) malfunction? MeetJoeAsian 5th gen T4Rs 4 03-12-2012 01:21 PM
Traction Control Malfunction??? glock56534 4th Gen T4Rs 8 06-07-2011 12:44 AM
vsc trac control malfunction tozar 4th Gen T4Rs 1 07-21-2010 03:50 PM
'03 Hill-Start major malfunction! hammersmith 4th Gen T4Rs 49 04-03-2003 12:45 PM
