Old 04-18-2024, 05:50 PM #16
Originally Posted by TRDHULK View Post
I'm sure this will be the boat I am in soon. I just don't want a big heavy bumper yet. I like my OEM+ look
nguyen has a hitch option, he just cant rate it for towing due to liability. find a good shop to weld it on and add reinforcements so you can trust it. '
his bumper/tire swing is the best looking IMO. followed closely by the 80% guy's stuff.
Old 04-18-2024, 06:13 PM #17
chrisridebike8 chrisridebike8 is offline
chrisridebike8 will become famous soon enough
Thanks for the feedback on the Rigd unit. That is one I considered, but I was worried about scraping it off road. It also sits farrr from the liftgate.
Are you saying Dissent offers a swing out without using the whole aftermarket rear bumper? I don't see it on their site.
Yeah. If you go Shop -> Swingouts it's under there. It goes in the hitch and you can have a single or dual swingout setup. and those swingouts can transfer to a bumper if you want.
Modular Hitch Mounted Tire Carrier (Single Swing)
– Dissent Off-road
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
chrisridebike8 is offline   Reply With QuoteReply With Quote
Old 04-18-2024, 06:17 PM #18
///AIRDAM's Avatar
///AIRDAM ///AIRDAM is offline
Real Name: Adam
///AIRDAM will become famous soon enough
///AIRDAM's Avatar
Real Name: Adam
Pull the spare tire out and take pix, or find someone who pulled theirs and did a lift gate spare and posted pix. I kinda think there are two braces that run parallel to the tires, that have like a hook on the front towards the rear diff to keep the tire from sliding forward. You might could actually cut those out and make a hoop/basket that would weld in higher than those cross bars that allows the tire to sit higher.
I have the 285 on my 4th gen and it hangs way down
i have the 305 on my 5th gen and it REALLY hangs way down. You can see like 3" of tire below the trailer hitch. I think it looks bishin but i can understand the approach and departure angles argument. If there is a brace that can be cut that would allow you to move the tire higher, you may wanna look at it. Also, using a roller to roll 1/4" flat bar the same radius as your 35" tire would allow you to section out the trailer hitch slightly and weld in the flat bar at the radius that would allow the 35" tire.
When i was putting the 305 under the wifes rig i set it back against the trailer hitch.
When i installed a rear backup light in the receiver, i had to let the tire down so i could push it forward to get the harness and plug to come out of the inside of the receiver and make it around the tire. I vaguely remember the receiver sticks out a little past the actual hitch bars further inward toward the tire. You could section this out and weld in a new radius piece and cut the cross bars up front and most likely fit the 35. Like that other guy above said, why not find a skinny 34" and run a little more air in it to match your 35s so it wont hang down so low if you cant mod the spare tire rack to move the tire higher. I am not around the 5th gen at the moment or i would stick my hands around the tire and see what kinda room it has. I think when i let the tire down and pushed it forward for the wiring of the trailer hitch, i had a solid 3/4" more room between the tire and the back of the receiver hitch but i am pretty confident there is an easy 1/2 you can cut off the back of the receiver before ever getting into the cross bars. But sectioning the cross bars with a radius to match your tire would be tits.
current
2005 Tundra DC limited + 2008 4R Urban Runner + 2023 4R TRD Sport
past
2008 Tacoma TRD Sport DC TRD supercharged + 2012 4Runner Limited
///AIRDAM is offline   Reply With QuoteReply With Quote
Old 04-18-2024, 11:50 PM #19
///AIRDAM's Avatar
Real Name: Adam
///AIRDAM's Avatar
Real Name: Adam
Yo, this bracket has a taper to it, you could get at with some metal fab and pocket this piece out pretty easily. Even if you had to build a new panhard bar with a radius forward. You could easily fit your tire
Would be smart to chop this bracket, maybe even make a radius panhard bar, and find a skinny 35 that would tuck up under there.
Crap I don’t have enough service to upload pix I’ll keep trying.
current
past
Old 04-19-2024, 12:03 AM #20
///AIRDAM's Avatar
Real Name: Adam
///AIRDAM's Avatar
Real Name: Adam
Got one to attach
Spare tire carrier options....-b41c7c8d-ea7b-46bb-a31a-64d3ee9d6ab5-jpg
current
past
Old 04-19-2024, 12:22 AM #21
///AIRDAM's Avatar
Real Name: Adam
///AIRDAM's Avatar
Real Name: Adam
Another
This back bar could easily be cut and a radius Piece of flat bar be welded in.
Spare tire carrier options....-90459bd1-0741-4c93-af6f-299f6792e5c7-jpg
current
past
Old 04-19-2024, 09:12 AM #22
///AIRDAM's Avatar
Real Name: Adam
///AIRDAM's Avatar
Real Name: Adam
Here is how much ours hangs down
I’m quite confident with slight modifications you can stuff a 35 in the hole. Section that one bracket at the dotted line, maybe slightly massage the hitch, run a skinny 35 for a spare. Should be solid. I kinda like the look of how this tire hangs down in ours. It’s meaty lookin. Both of mine hang down line this.
Spare tire carrier options....-b4a154e6-d43a-4764-a1ea-3b89b88236f7-jpg
current
past
Old 04-19-2024, 11:56 AM #23
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
Thanks for the pics and info! I might give this a shot!
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
TRDHULK is offline   Reply With QuoteReply With Quote
Old 04-19-2024, 01:19 PM #24
Saker's Avatar
Saker Saker is offline
Saker's Avatar
This is an original CTNewman carrier.
Camera: I moved my original camera to the center of the wheel mount.
SSO is still making them as of my last conversation.
I think they currently make the offset for the ladder. They have all the plans in hand for the offset and the center carrier.
SSO is local to me.
I had the same feelings about all of the other carriers and that is the reason for me purchasing one from CT.
PM me for more information.
Excuse the dirt in the photos.
Best Regards,
Saker
Old 04-19-2024, 02:28 PM #25
TRDHULK's Avatar
TRDHULK's Avatar
SSO is local to me.
That one looks great! Please send me the info on where to buy.
When I reached out to SSO, they said:
"sorry we dont have an eta on the tire carrier at this moment"
I said can I order one?
They replied:
"I'm sorry I dont have info readily avaialble"
Old 04-19-2024, 06:14 PM #26
Saker's Avatar
Saker's Avatar
They replied:
OK..........
I spoke with the same person at SSO that you spoke with and
I can confirm as of today, they do not have an eta on the carrier. (sorry for any misleading data)
Also, they do not have any readily available.
They are the only people that have CT's plans on this carrier.
They have a backorder on these currently and I hope they will get back on schedule manufacturing these....
Best Regards,
Saker
Old 04-19-2024, 06:34 PM #27
TRDHULK's Avatar
TRDHULK's Avatar
OK..........
All good man!
I was fairly surprised at their response...
Who knew it would be so hard to find a spare tire solution that I like
Old 04-19-2024, 09:08 PM #28
Saker's Avatar
Saker's Avatar
All good man!
Don't give up the fight.
Check your PM's
Best Regards,
Saker
carrier , options , rear , spare , tire
Spare tire carrier security / Dmos tire mount mrblah 5th gen T4Rs 0 11-11-2023 09:18 PM
WTB: Spare tire carrier for 03-09 pearlj10 Want to Buy/Trade 0 12-11-2016 12:50 PM
WTB: 4th Gen Spare Tire Carrier and Carrier Guide jkemp Want to Buy/Trade 0 10-09-2015 02:17 PM
Spare tire carrier? 2nd gen. mack1 Classic T4Rs 7 09-24-2014 04:26 PM
Spare Tire carrier options? Gen2 chenson Classic T4Rs 5 04-08-2011 04:05 AM
