Love the awning light setup, any more details on this?
Surely.
Well of course firstly it's an ARB 2500x2500mm awning. You can get the more expensive ARB proprietary LED light, but I don't like that you have to set up and hang the light every time.
It's a trimmable light strip so you can get the full length of the awning frame, and it's one-sided adhesive allows you to stick it permanently right inside the frame.
The disconnectable controller has a dimming function and you can simply unplug the wiring when not in use. The connecter at the rear of the awning tucks easily back into the awning bag when it's time to pack up as well. Also, the power cord is the perfect length to plug into the back 110 outlet and run to the right side of the vehicle. The cord won't reach if you have a left-side awning mounted.
2019 TRD Pro Voodoo Blue "Cobra Commander"
Love the old school wheels! Question - do those D-rings of yours bounce around? If not, what type of inserts are you using to keep them in place on the front tie-downs?
The D-rings are from gearamerica, they come with rubber spacers to prevent them from bouncing around.
