Question on towing and break-in period
RyanE
Got my Black/Black Limited w/Nav & 3rd row ordered last week...should be at the dealership in about 2 weeks. I can't wait to pick it up.
Since the dealership I ended up buying from is about 4 hours away and I'm not trading my other car in, I'm considering the option of using the 4Runner to trailer my car back. My car weighs ~ 3300 lbs, so I'm within the towing limit, but I'm having a hard time believing it's a good idea to use my 4Runner for towing before it goes through some kind of break-in period.
That said, is there a defined or recommended break-in period or procedure for the T4R? If not, is there a general opinion on whether or not towing right away is a good idea? Common sense tells me 'no', but I'd like some more educated opinions than my own.
Thanks.
Thanks.
According to the manual:
Tips for breaking in your new Toyota
For the first 200 mi avoid sudden stops
For the first 500 mi Do not tow a trailer
For the first 1000 mi:
Do not drive at extremely high speeds
Avoid sudden acceleration
Do not drive continuously in low gears
Do not drive at constant speed for extended periods.
Being 4 hrs away, you are going to have a hard time with the constant speed.
The tips are almost impossible to follow, I had to tow a trailer with 300 mi on my 4R and broke the constant speed tip as well.
Perfect response, thanks. For some reason I hadn't considered trying to find the owner's manual online.
Looks like I'm going to have to bribe a family-member to spend a day on the road with me. Shouldn't be a problem, I just don't like other people driving my cars.... :driving:
I should be able to break up the speed a little instead of just setting the cruise and running with it.
Thanks again for the quick, helpful response.
