Old 12-09-2013, 08:14 PM #16
Stifler Stifler is offline
Banned
Stifler is on a distinguished road
Banned
what I want to know is what is a good stubby antenna
Stifler is offline   Reply With QuoteReply With Quote
Old 12-09-2013, 09:04 PM #17
mace.'s Avatar
mace. mace. is offline
mace. is on a distinguished road
mace.'s Avatar
Will a stubby antenna give me an aerodynamic and weight saving advantage to be able to tow 5012 lbs.
mace. is offline   Reply With QuoteReply With Quote
Old 12-09-2013, 09:15 PM #18
MTD's Avatar
MTD MTD is offline
MTD is on a distinguished road
MTD MTD is offline
MTD's Avatar
Originally Posted by rtj913 View Post
I just called Toytec. I have a 2013 Trail edition and just put the 3" ultimate toytec lift on. I asked them what size tires I could put on with stock 17" rims. They said 285 / 70R /17s. What is the experience you folks have had if any with this. Cutting needed Etc. I wanted to put General Grabbers on it 33X12.5 / 17s is there an offset and or back space needed to fit these tires? Thanks guys!
Originally Posted by joneseyyy View Post
Celebrating the three year anniversary of the last post in this thread I see...plenty of other "will they fit" content on here.
I think it is funny how people catch flack for starting new threads when there is already one pertaining to what they want to know, but then people make fun of them for commenting on an old thread.
Need something 3D printed, T4R.Org members get 10% off @ my 3D Hub!
Custom 3D Printed Retro and Other Badges!!
MTD is offline   Reply With QuoteReply With Quote
Old 12-09-2013, 10:48 PM #19
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
Mangowalk
@rt: I run a 32.8x11.5 on a 17x9 wheel with 5.5 backspace and -12 offset (same as stock, so the extra width over 265's is split equally between the inboard and outboard side). I ride on 3" of lift, have done the fender liner mod, and have my castor cranked up to around 4 degrees, but I still rub in the mud flaps at full lock in reverse.
You might be able to get away with a little less offset, but a mount chop will be in your future for sure. Definitely do not even consider going to a 33" without UCA's.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 12-10-2013, 02:03 AM #20
scjo06's Avatar
scjo06 scjo06 is offline
Real Name: Matt
scjo06 is on a distinguished road
scjo06's Avatar
Real Name: Matt
I'm running 285/70/17s with a stage 5 kit. I also have MT's upper and lower control arms, so it guess it could be considered a stage 6-ish. Anyway, I'm trimmed and cut and I still have rubbing issues when in reverse at full turn. You probably could push the 305s under there with minimal issues but the 315s? It would be rub city.
Yes.....I need to update my sig.
2013 Mag Grey TE KDSS/NAV (stock for now)
1988 FJ62 "YoLanda" Land Cruiser-beaten but not defeated
Upstate Cruisers
TLCA#15219
scjo06 is offline   Reply With QuoteReply With Quote
Old 12-10-2013, 03:43 AM #21
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
My next set of tires are going to be 34s. I am re-gearing soon too. I know the body mount will need to be cut. Then I will bust out the BFH for other stuff.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 12-10-2013, 04:08 AM #22
mdogg mdogg is offline
mdogg is on a distinguished road
I don't think either of those (backspace or offset) is same as stock. Backspace is 4.5" for SR5/LE and 4.875" for TE. I believe the offset is +12mm for SR5/LE and around +15mm for TE (not sure on the TE honestly). Sounds like your wheels are significantly different than stock.
mdogg is offline   Reply With QuoteReply With Quote
Old 12-10-2013, 03:31 PM #23
Jono.ful's Avatar
Jono.ful's Avatar
4.5" of backspace on a 7" wheel is equal to 12mm of offset, 5.5" backspace on a 9" wheel is also equal to 12mm of offset. Have a look:
http://www.hubgarage.com/mygarage/Ca...photos/1610931
Edit: double checked my own wheel specs, they are different from what I remembered, and I also mistakenly thought the stock wheels were a negative offset for some reason (mine are actually 17x9, 4.5"bs -12 mm offset), but the above is still true
Old 07-26-2015, 10:04 PM #24
CROWN14's Avatar
CROWN14 CROWN14 is offline
CROWN14 is on a distinguished road
CROWN14's Avatar
Hey CGill,
Like your rig.
Can you tell me what size Wheel/Back spacing/and offset you used ?
It looks likey they fit nicely in the wheel wells even though you went quite a bit wider.
Thanks.
CROWN14 is offline   Reply With QuoteReply With Quote
Old 07-26-2015, 10:29 PM #25
carlomagne's Avatar
carlomagne carlomagne is offline
carlomagne is on a distinguished road
carlomagne's Avatar
revived an old thread but kinda glad he used the search button.
2019
Carlomagne's Random Offroad Photos
carlomagne is offline   Reply With QuoteReply With Quote
Old 07-27-2015, 12:09 AM #26
Hellamatic's Avatar
Hellamatic Hellamatic is offline
Hellamatic is on a distinguished road
Hellamatic's Avatar
Originally Posted by CROWN14 View Post
Hey CGill,
Like your rig.
Thanks.
I've got the same wheels - mine are a -12mm, though I'm only running a 285/70. Maybe a quick check of the Ultra website might give you available offsets for our bolt pattern in a 17" and you can do some detective work. Any proficient tire shop should be able to help you decide from there with some basic measurements.
2012 4Runner Trail Edition....None more black
Hellamatic - Build Thread
Hellamatic is offline   Reply With QuoteReply With Quote
Old 07-27-2015, 12:50 AM #27
Orlyg1521's Avatar
Orlyg1521 Orlyg1521 is offline
Orlyg1521 is on a distinguished road
Orlyg1521's Avatar
Rub
When I bought this truck it had 35's and the rub was bad, also the gas mileage was 12 mpg. For both those reasons I sold them and went to 33's
35inch tires-4runnerpic-jpg
Orlyg1521 is offline   Reply With QuoteReply With Quote
Old 07-27-2015, 10:16 AM #28
CplTurner's Avatar
CplTurner CplTurner is offline
Real Name: Allen
CplTurner is on a distinguished road
CplTurner's Avatar
Real Name: Allen
Check with Jason Demello. He might be willing to tell you what was involved in stuffing 35's under a 5th Gen.
35inch tires-img_0670-jpg
Regards,
CplTurner-W4AGT Instagram: #rockcreekoverland
2015 TRD Pro-OME 3" Lift, STT Pro 285/70/17, SpiderTrax, Gobi Stealth/ladder, Tepui Ruggedized Autana RTT, Budbuilt sliders, RCI skids, ARB Awning, ARB 50L Fridge
CplTurner is offline   Reply With QuoteReply With Quote
Old 07-27-2015, 10:23 AM #29
chmura's Avatar
chmura chmura is offline
chmura is on a distinguished road
chmura's Avatar
Attachment 166740
Needs little more lift!
To me 285/75/17 and 295's look the best on a 5th gen. These are 34" tires.
Anything that wide as in Demelo's picture just does not look proportional to me. Sure he fit them. But look how close the tires are to the fender flares? I bet he rubs when going up driveways at a 45 degree angle. You simply cannot off road that thing with full stuff! Maybe you can if you ware earplugs so you dont hear the tires rubbing on everything..
Any 35" tire on the roof rack? How the heck do you get a tire up/down there that big by yourself? You simply can't!
2009 Trail Edition - ICON lift, Total Chaos UCA, BF Goodrich Mud Terrain KM2 285/70/17's, SCS Stealth 6 Matte Gunmetal finish, K9 2.2m Roof Rack.
chmura is offline   Reply With QuoteReply With Quote
Old 07-27-2015, 11:20 AM #30
SouthernSS SouthernSS is offline
SouthernSS has a spectacular aura about SouthernSS has a spectacular aura about SouthernSS has a spectacular aura about
295/70-17 Coopper SST's
34" tire required body mount chop, caster to nearly 4 degrees and some plastic trimming of the front bumper
35inch tires-20150717_125611-jpg  35inch tires-20150717_125510-jpg
SouthernSS is offline   Reply With QuoteReply With Quote
tires
How Hard Is It To Stop a Prius? trev0006 General Discussions 12 03-15-2010 02:59 PM
Taller Tires Don't Get You As Bad Gas Mileage As You Think? Spencer 3rd gen T4Rs 24 09-15-2009 11:03 PM
Tires Tires Tires!! Elemenohpee619 3rd gen T4Rs 19 02-10-2009 05:44 PM
16" wheels/tires, set of tires terrytcl Classifieds - buy & sell (no commercial ads please) 1 12-21-2004 04:08 PM
Michelin tops in tires again: J.D. Power Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-18-2002 05:05 PM
