97 SR5 keyless entry programming...i know right?
i have a 97 SR5 with the rs3000 system under the driver seat. i have a key fob, grey with black buttons with the FCC BAB237131-022 id. i have followed the steps in the rs3000 manual. but it does nothing after hitting the button the fob. i can hold down the green button, led on console lights up, hit the fob button and nothing. i've been searching the forums but most everyting is written for the newer 3rd gens with securikey...from what i gathered that's significantly different and that's where oyu have to unlock/lock 5 times.... can someone tell my if i have the right fob and am doing teh right pairing sequence.
this is what i'm doing
To program (add) a remote control to the system:
1: Insert the key into the ignition switch and turn it to on.
2: Press and hold the ECU's programming switch for 3 seconds. The status monitors LED turns on for 5 seconds.
***You must perform the next step within 5 seconds***
3: Press and release a remote controls top or bottom button. Either button on your remote control can be programmed to operate the RS3000. The status monitors LED turns off. The piezo chirper chirps once. The exterior lights flash once.
4: Turn off the ignition. The ECU will now operate with the remote control just programmed.
Note: The factory preset operation is for the top button on both remote controls to operate your system; the bottom button is not programmed. To prevent accidental erasure of a remote controls code, we recommend that you program all your remote controls at the same time.
