Originally Posted by turbodudey2
For this to work you'd need to have a receiver in the front bumper to mount the truss to. And then another fairlead in the rear bumper to feed the winch rope through to direct it out the back. You'd just use the pulley out front to change the direction of the winch rope, run it under the truck and through a fairlead in the rear bumper.
You'd probably have to build a bumper specifically for this purpose since you could have up to double the winch capacity on the pulley and that could create be a pretty large moment on the bumper.
Yuu will need to change the direction one more time.
If you want one winch set in the middle, this probably won't be possible with a smaller vehicle. If you pull from the top of the drum one the front and from the bottom for the rear it would work.
The best solution would be wheel with a buddy where each of you a winch have or mount two permanent winches. By the time you pay for all the fab work to make a mulit mount strong enough you could probably have almost enough for a couple of winches.
