View Single Post
Old 03-17-2011, 01:20 PM
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all TheDurk is a name known to all
TheDurk's Avatar
Dome wiring
Driver Side J/B
I can't see anything in that circuit, other than the Body ECU, the Back Door ECU or the Combination Meter (dash gauges) that would be damaged by reverse polarity. It's all switches and lights, otherwise. So you have to track down the short. Look at the links above. At the junction box by the driver's left knee, there is Connector 1E that carries the whole circuit. Open that connector and see if fuse still pops. (Unlikely, but then short is between there and the fuse.) Reconnect 1E. Then open connector 1A and 1F in turn. ONE of those should have the short. Then just follow the short back through the circuit until you isolate it. For example, if it's in 1F, then try 3C in the Center J/B. I don't know how else to do this.
Actually, I'd start by pulling B16 from the Body ECU. My WAG is that's the most likely spot. Then I'd probably be wrong and and have to start the way I described.
My Backyard Frame Swap
