View Single Post
Old 03-01-2005, 11:24 AM
TeryT's Avatar
TeryT TeryT is offline
TeryT is on a distinguished road
TeryT's Avatar
Originally posted by wkparker
TeryT, I'm not sure about the impedance of the center speaker, but if it is 4 or 8 ohms and now the amp sees a 25 ohm load, sooner or later you may cook the amp. You really need something that changes the volume while showing the amp a constant load - like the in-wall volume controls for whole-house audio systems. Little big for a T4R if you want to be able to access it, though.
Thanks. That is one reason I want a switch that doesn't go as high. If I can't find one, I would set it only at the minimal range - say 2-3 ohms. This reduces the volume pretty well. I'm told these speakers are 2 ohm, so the most the amp would see is around 5.
Does that sound OK? What about just leaving the speaker disconnected (which would be the 2nd best option)?
2003 V8 4x4 Sport 4Runner TRUCK OF THE MONTH SEPT. 06 - still tows a 25' ultralite Rockwood 2502 travel trailer all over creation!
MODS: GlowShift tranny temp gauge; Hayden 526 tranny cooler/fan combo; Hopkins Insight brake controller; Bilstein 5100 shocks
Hensley Arrow hitching system - quite simply the best for zero sway towing!
TeryT is offline   Reply With QuoteReply With Quote
