View Single Post
Old 04-26-2011, 08:05 PM
cj80cruiser's Avatar
cj80cruiser cj80cruiser is offline
cj80cruiser is on a distinguished road
Originally Posted by gretschdrum View Post
Hey Gang,
I’m having a retractable antenna issue that I have not seen reported on this, or any other, forum. I hope someone can help with it.
I have a 98 SR5. I took the vehicle in for a 210,000-mile service and to have the main drive belts changed. When it came out of the service I turned the radio on as I was leaving the dealership. The antenna went up to its fully extended position but the antenna motor kept running. The antenna made a grinding noise for about 10 seconds AFTER the antenna was fully extended and then it stopped. When I shut the radio off the antenna retracts perfectly and the motor stops when it’s fully retracted. FYI, the radio works perfectly.
Another symptom is that I can turn the engine off but leave the ignition in the ‘ACC’ position. The radio will stay on fine and the antenna stays up. However, when I turn the engine back on the antenna motor starts AGAIN and grinds the already fully extended antenna for 10 seconds and then stops.
Ideas? The mast? The antenna relay? The antenna motor?
This entire thing started immediately after the 210,000-mile service at the Toyota dealer. I mentioned it to the service tech and he said it was total coincidence and that nothing near the antenna was serviced.
Makes me wonder if they had something hung up over the side of your truck to keep from scratching up the paint, forgot about it covering your antenna and when they started your truck up the antenna went up carrying the cloth...meanwhile the hood caught the cloth and wouldn't let your antenna go up which resulted in your now clicking problem......
This is the only conclusion I can come up with for the coincidence and its a stretch but a possibility.
戦争イーグル
Cory J
Wheel converter,
cj80cruiser is offline   Reply With QuoteReply With Quote
