Originally Posted by GottaBeTRD
sweet thanks for this man! i gotta get it done now! i always get a little worried messing with all the wires
i'm basically just trying to hook up two strips to come on when the domes come on did you use the wire under the door sill to tap the power?
Do you want them to come on when you switch the dome light on manually or you want them to come on when the doors are opened? Mine are set to come on when the doors are opened. So one wire goes to the door trigger wire (black/white) that is a negative wire and my positive goes to a relay I used for my alarm which is connected at the ignition switch for constant power.
