Yep, just replace the bulbs. Pull the little cubby out under the display. Remove the one screw and pull the display out. The bulb are remove with a small screwdriver.
2007 SportEdition V6 4WD Galactic Gray
Found on the trails of the Colorado front range
Daystar 2.5/1.5, Rear Diff Breather Mod, TRD Brake Pads, Full Synthetic 90w-135 Gear Lube, 265/70/17 Duratracs, Cobra 75, 3' Firestik, Refrigerated Console
Toyota Expert Tech/Lexus Certified Tech/ASE Master Tech
